MPC2011 using smtp.gmail.com
  • keithxxiii
    Just a tech
    • Nov 2014
    • 468
    Hi folks,
    Just wanna ask if you have configured Ricoh MPC2011 using gmail smtp.
    I had a call about 6 months back requesting to configure scan to email using gmail smtp. Tried every possible way like configuring other machines.
    Today I had another 1.
    administrator email (company@gmail.com)
    smtp server (smtp.gmail.com)
    port (587, tried with 465)
    SSL (ON)
    smtp authentication (company@gmail.com)
    smtp email address (company@gmail.com)
    encryption (tried with auto, on and off)
    allow less secure apps is (ON)
    Tried with a working configuration using a gmail address as well.
    This normally works with other 03 and 04 devices.
    Is there anyone from the team who faced the same issue?
    Aye! Cut the crap
  • mincopier
    • Dec 2015
    • 289
    Re: MPC2011 using smtp.gmail.com
    First update the firmware. Make sure the Admin Email is the same as the authenticated email. It may also be possible the machine is too old to use Gmail or Office365. If that does not work try using relay.appriver.com on port 2525. No authentication. Make sure the admin email has an actual domain name to the right of the "@" symbol. Appriver this way maybe a little slow but usually works.
    • sandmanmac
      • 3979
      This is very handy information.
      I've read a lot of info about scan to email, and I myself typically use smtp2go when the need arises on older machines that don't support encryption, etc., and I've never heard of this service, but I just tried this on my home machine and it worked perfectly.
      It doesn't get any easier.
        • 37375
        Try using:
        smtp server (aspmx.l.google.com)
        port (25)
        SSL (OFF)
        company@gmail.com must be a valid email account and must have allow less secure apps (ON)
        If company@gmail.com is a Google Suite account or part of a Google Apps domain you may have to modify you MX records. Contact Google Suite support for details or Google aspmx.l.google.com
          • 29936
          add 8.8.8.8 to DNS
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            Originally posted by keithxxiii
            Hi folks,
            SSL (ON)
            I see you've turned on the allow less secure apps, but is this a Google for business account? A few times Google has burned me with that. Twice now I've seen this where it lets you set it and looks like it is set but it really ins't. Only after trying a second time does it give some message about only an admin can change this setting.
            Logon to: admin.google.com
            From there set the allow less secure apps. It was really frustrating because the slider was set and there was no warning. Only when I tried turning it off/on again did I get the message and even then it still let me move the slider. I hope Google fixes that soon.
            • keithxxiii
              Just a tech
              • Nov 2014
              • 468
              It's a newly created google account. I've been setting up scan to emails before with other machines using office365 and local smtp relays from clients. I even tried smtp2go but no luck. It's a small office on a workgroup setup. DNS 8.8.8.8 is set as well. I'm gonna try to setup the aspmx.l.google.com and relay.appriver.com but the customer is on holidays. I will give an update as soon as they ring me back.
              Aye! Cut the crap
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                MPC2011 is a base model of MPC2003. The web interface is the same. Firmwares are up to date as I updated it using @remote.
                I will play with appriver in my lab first then try to set up there.
                Aye! Cut the crap
                • mincopier
                  • Dec 2015
                  • 289
                  Just looked up the MP C2011. On theRicoh TSRC site it did not show up. Did a global search on Google and came across it. It looks to have the first Gen of the Smart Op Panel. It is curious that G-mail is not working.
                  Another thing that I have come across is sometimes you may need to log in to the G-Mail account and give permission through an incoming email. Sometimes G-Mail, especially if the account was created offsite, detects the login as an attempted unauthorized login of the account.
                  Not having access to the firmware for this machine I cannot double firmware problems and levels.
                  for the aspmx.l.google.com on port 25 I have not tried in a long time. When I did use this server it was without authentication. It is my understanding that with this server it only sends to other G-mail accounts. Now that was without using authentication. With authentication it should send anyplace.
                  May also be possible that the customers network may have the SMTP protocol blocked for certain IP ranges.
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 468
                    Hi,
                    I went to the customer's place and found out that the router they were connected to is an AP extension from the next office. I am suspecting that the ports were blocked. I was fortunate that I had my Netgear Adapter with me which I use for extending wireless. I connected the device and used my 3G for tethering so to have internet access. Upon testing, it worked fine.
                    Thanks for your suggestions.
                    Aye! Cut the crap
