RICOH CW 2200 SP
  • claudioterrible
    no mercy...
    • Oct 2008
    • 96
    RICOH CW 2200 SP
    Hello fellas ! I recived a ricoh cw 2200 as part of a payment,i work with ricoh copier since many years ago,but the question is: How could i loggin in the sp mode? I was trying with the both loggin but i couldnt do it ,anyone can help me? Anyone knows the right access for this model? ( is the only one wide format that i have) thank you all!!
  • mikadonovan
    • May 2008
    • 2931
    Re: RICOH CW 2200 SP
    Same SP access as previous Rich MFP's up to the 02 models.
    NEVER ASSUME ANYTHING
      • 37560
      It is possible to change the SP login code. If that has been done, you need to either contact that person or use factory SP mode.
      • claudioterrible
        no mercy...
        • Oct 2008
        • 96
        Reset/ 806182/clear (holding) then while keep pressed # (special service)?
        Or reset/107/clear (holding) then while keep pressed # (special seervice)?
        I tryed with these but nothing happened
          • 37560
          Because you are doing it wrong.
          Either Yellow 1 0 7 Red holding red until SP menu comes up or Yellow 8 0 6 1 8 2 Red holding red until SP menu comes up. If you then want to go into special SP mode hold the # while selecting and pressing the desired SP mode.
          • guitar9199
            • Sep 2016
            • 1100
            Sounds like the previous "owner" may have changed the SP Mode password. There is a way to reset it in Factory SP Mode, but I'm not putting that information out in the public forum. I'd suggest opening a trouble ticket with Ricoh help desk and let them walk you through it.
            • mikadonovan
              • May 2008
              • 2931
              Normal SP access for this model is clear modes>107>hold down on clear/stop.
