MP C3500 Error Messages
  • KirkG
    • Jul 2017
    • 12
    [Misc] MP C3500 Error Messages
    I have a Ricoh MP C3500 that is giving the following Error messages: "Photoconductor Unit(s) not set correctly" and "Set Toner Cartridge(s) correctly"...I have removed and installed All of them several times..Can not Clear Error message. There is NOT an Error Code with this message either. Anyone help with this one??
  • Lagonda
    • Aug 2008
    • 1649
    Re: MP C3500 Error Messages
    My first response would be to pull all the PCDU's out and have a good look at the sockets they plug into and check that they are not full of toner or paper scraps.
    What did you do to the copier just before it decided that it wasn't happy?
    • davel
      • Oct 2011
      • 1109
      If you have just replaced PCU you may need to swap wires on TD sensor plug.
      • sandmanmac
        • 3990
        Agreed. Swap wires, or just make sure the connector is properly secured.
        ALSO....These things usually don't just happen out of the blue, why would you include what led to the issue?
        If it was for no apparent reason, then, my apologies.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          If they were modified B223 2042 drums you have to shave the rear connector of the drum to make it fit the drive assy connector or you'll break the drive assy connectors.
          Broken connectors would give you this fault and replacing the drive assy is a royal pain in the arse...!!!!!
          • mikadonovan
            • May 2008
            • 2931
            And bring 2 days lunch, as it takes a lot of time. And you will need 4 hands.
            NEVER ASSUME ANYTHING
            • mikadonovan
              • May 2008
              • 2931
              An issue with any one of the pdcu connectors will cause this. Did you mess with any of the PDCU's previous to the problem?
