FTP Scanning
  • tufbnme
    • 493
    FTP Scanning
    This was shared with me and I thought i would pass it along.
    I know there are techs out there having issues with SMB and wondering how to setup FTP.
    Your welcome
    Scanning with FTP_FileZilla.pdf
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: FTP Scanning
    I will never use this software, nor will i recommend it to my customers.
    I don't think it's save.
    • davel
      • Oct 2011
      • 1107
      Re: FTP Scanning
      Up to you. What FTP do you use?
      • mansart
        • 852
        Re: FTP Scanning
        Quick 'n Easy FTP Server Lite
        • NeoMatrix
          Senior Tech.
          • 3513
          Re: FTP Scanning
          Scan to FTP using a NAS or private cloud.
          No additional FTP server or other FTP software required.
          http://www.copytechnet.com/forums/co...tml#post694379
          htttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software.html#post694379
          HTH
          • JR2ALTA
            • Feb 2010
            • 2033
            Re: FTP Scanning
            I can't speak as an IT expert but I know Konica has stopped supporting FTP due to it's security vulnerabilities.
            • Mark Bbb
              • Jun 2012
              • 1662
              Re: FTP Scanning
              Originally posted by mansart
              Why should you use software if scan to map (folder) works fine?
              What is the benefit of scan to folder software (as the one mentioned above)?
              I don't trust free software, and if you need to pay for it than it needs to be realy good with lots of avantages!
              So?
              • sturmtrooper
                Copier Combobulator
                • May 2016
                • 587
                Re: FTP Scanning
                So?
                There are many old MFPs that will not do SMB scanning to windows 10. Scan to FTP will work though.
                • mincopier
                  • Dec 2015
                  • 289
                  Re: FTP Scanning
                  Filezilla software is just as secure as Quick and easy FTP server lite. Nothing really wrong with either. The only thing I do not like about Filezilla is it is too robust for scanning to one computer.
                  SMB vs FTP: Olde machines are not the only problem with SMB. A lot of newer machines are not working with SMB due to Microsoft changing security features faster than manufactures can come up with updated firmware.
                  I have not seen anything about Konicaminolta not supporting FTP. It can be just as secure as SMB with authentication. FTP does not have to be Anonymous like the default setting of the Konicaminolta FTP Utility.
                    • 30294
                    Re: FTP Scanning
                    DO to Microsoft and apple continue to update there OS systems IE changing SMB requirements and screwup what works. I have been forced to use either scan to email or scan via FTP.
                    I have always used filezilla server and never had an issue.
                    • ricmartinho
                      • 142
                      Re: FTP Scanning
                      I also use Filezilla but I install it differently. In the beginning I used Quick n easy FTP but kept getting a lot of calls because users stopped the server by right clicking on the icon next to the clock.
                      When I install Filezilla I uncheck "Start Menu Shortcuts" and "Desktop icon" and on "Please choose how the interface should be started" I choose "Start Manually". This way Filezilla is hidden for the users (you don't have to go to settings and choose "Start Minimized") but the FTP server still runs on the background. I also don't create a group, I just create the user.
                      The only problem I have is that I can't get Filezilla to work with the hostname of the PC. I always have to change the PC to a fixed IP (or lock it in the router).
                      With Quick n Easy I didn't have that problem. It worked with host name as a charm.
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        Re: FTP Scanning
                        Re. I can't get Filezilla to work with the hostname of the PC.
                        Filezilla probably can't find the DNS server.
                        The firewall could be blocking local ARP requests?
                        Is the entire network DHCP or all fixed IP's?
                        If its a home/small office router: assign the router as a [x] DHCP server and point Filezilla to the router as its DNS server.
                        If changing to a DHCP network;you may like to reserved router fixed IP's address to the printers etc...
                        HTH
                        • Jures
                          • Apr 2020
                          • 3
                          Re: FTP Scanning
                          Hi There.. i think you are just the guy i'm looking for.
                          i also am struggling to get filezilla working with the computer hostname and i need to set it up like that as the client's ip changes and then the setup needs to be done again.
                          i see here that you used quick and easy ftp and it work with the host name, i did download quick and easy ftp but still does not work with the host name.
                          is there any tips you can give on how to get this working with a host name please.
                          Thank you.
                            • 37532
                            Re: FTP Scanning
                            Thank you.
                            Go away grave digger.
                            This thread is over a year old and therefore is dead and buried.
                            • Jures
                              • Apr 2020
                              • 3
                              Re: FTP Scanning
                              Listen Asshole... if you don't have the answer I'm looking for don't rely to my message!!
                              Obviously you don't ..!!
