Ricoh mp c4503 print jobs are coming out in washed out colors
  • gregm27
    • Mar 2018
    • 15
    When print jobs are sent to the copier, the colors look washed out and faded. Printing a test page in printer sp mode, the colors are much better looking
    • 30390
    Re: Ricoh mp c4503 print jobs are coming out in washed out colors
    Install pcl 6 driver
    • Mark Bbb
      • Jun 2012
      • 1662
      Go to maintenance, auto colour calibration, perform those refering to printing.
      Is the mimage on the printout also blured?
      If no, proceed the calibration procedure.
      Better?
      • gregm27
        • Mar 2018
        • 15
        Thank you. We did install the latest pcl 6 driver from Ricoh web site. No PS card installed in machine, btw. Does this mean the problem more than likely is with the computer and not the copier?
          • 30390
          Could be , will install a new machine an account that had an HP, customer had tuned all files to match the bad HP printer so when we install new printer customer said color was off.
          Take the file and print to another color machine on or off site and compare. Or use a known color file and print it.
          • gregm27
            • Mar 2018
            • 15
            Going back on site tomorrow. Will try suggestions and post here results. Thank you!
            • mikadonovan
              • May 2008
              • 2931
              Make sure the ID sensors are clean.
              NEVER ASSUME ANYTHING
                • 37556
                Depending on the driver used, toner saving might be turned ON.
                • Zaxxon
                  • 608
                  Please start you post with brand, model, problem.
                  • gregm27
                    • Mar 2018
                    • 15
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      What sort of life are the PM parts in? PTR is a good cause of this kind of image quality problem.
                      Hit it.
                      • gregm27
                        • Mar 2018
                        • 15
                        Forced line postition adjustment fails as well as color calibration under maintenance
                        • Zaxxon
                          • 608
                          May we ask for a sample?
                          • JDYAL
                            • Sep 2008
                            • 187
                            Any sc codes in the recent history? Maybe image transfer or PTR as mentioned above
                            • gregm27
                              • Mar 2018
                              • 15
                              I
                              I have uploaded the printer SP test page
