GW EMAIL
  • LNorris
    • Sep 2008
    • 645
    GW EMAIL
    has anyone set this up? we have configured it, but not getting the test emails
  • JaysOnTheEDGE
    • 61
    Re: GW EMAIL
    Make sure the SMTP and E-mail settings are setup in the User tools screen as well. Had one i setup that wouldn't work until i setup the SMTP address.
    • LNorris
      • Sep 2008
      • 645
      Re: GW EMAIL
      user is able to scan to email normally, so not sure at this point. another tech is trying to set it up. we received instructions to set it up, but not getting the tests at this point.
      • ricmartinho
        • 142
        Re: GW EMAIL
        Search for this RTB on my-ricoh.com Knowledge Base:
        RTB No.: RGene102 : How to configure the Device Counter E-mail function.
        On some models this funcion is only available after FW update.
        • LNorris
          • Sep 2008
          • 645
          Re: GW EMAIL
          OK, thanks
          • LNorris
            • Sep 2008
            • 645
            Re: GW EMAIL
            found a video nugget. seems we werent rebooting it. we will try that tomorrow.
            • mincopier
              • Dec 2015
              • 289
              • Klydon
                • Mar 2009
                • 243
                Re: GW EMAIL
                This is likely your culprit. I have set up several and you have to reboot them or it generally won't work. Also, depending on the speed of the network and server, it might be a bit before you get your test email. I had one arrive 30 minutes after I did the test one time. Typical is going to be within 5 minutes.
                • mrwho
                  Major Asshole!
                  • 4299
                  Re: GW EMAIL
                  Sorry to revive this old thread - new machine IM 2702 doesn't seem to have it.
                  Could it be Ricoh, as usual, discontinuing something just as we're getting used to it?
                  Mascan42
                  Ibid
                  • FrohnB
                    • Jul 2017
                    • 1919
                    Re: GW EMAIL
                    IM 2702?? must be an Asia model?? A google search brings it up, and it looks like an "updated" MP 301. Not available in the U.S.
                    We have an IM C400 and an IM 350f in the shop that both have it, so I'm not sure why it wouldn't have it.
                    SP 5866 only shows 1 and 5?
                    Omertà
                    • ricmartinho
                      • 142
                      Re: GW EMAIL
                      In Europe, it's the sucessor to the Kir-C4 (MP2001/2501). It's an A3 BW model with a smaller SOP v2.5.
