mpc6502 asking for new Y toner message
  • dhg
    • May 2011
    • 26
    i have tried 2 new oem cartridges, swapped peizo sensor and motor.
    has anyone has this issue on this model ?
    Ricoh said replace hopper so i ordered on
    thanks dg
    Re: mpc6502 asking for new Y toner message
    thanks dg
    what are the life counters on: Dev - Drums - Waste - Belt?
    OEM Ricoh Toner?
    Environment of the workspace of unit?
    PM's done on time?
    have you tried to clean out toner supply/waste sections?
    So many questions so little info given.
    • dhg
      • May 2011
      • 26
      OEM Ricoh Toner?
      PM's done on time?
      Machine In non-production environment, total meter is around 100K.
      i vacuumed out hopper prior to swapping sensor and motor.
      oem ricoh toner...
      thanks again
        oem ricoh toner...
        thanks again
        How long has it been in place...
        Even tho might be below PM count...age/environment all play a factor.
        Hopper.. ok.. tubes to dev
        ITB to waste...?
        MORE info on really been done.. counters..etc could help
        • JDYAL
          • Sep 2008
          • 186
          Had quite a few toner hoppers go out on these models. As phil said check the tubes because they get backed up. The auger in the hoppers get bound up and snap.
          • dhg
            • May 2011
            • 26
            Thank you !
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              +1 for the Hopper assy.
              At only 100k it's a baby.
              • dhg
                • May 2011
                • 26
                It was the bottle motor failing intermittently !
                hopper did not fix
