Fax report MP2501
  • Bole
    • Dec 2012
    • 34
    Fax report MP2501
    Hi
    I need your help how can I find and change Fax TX report on Ricoh MP 2501sp. I checked all user mode and I dont find how to change printing TX report for every fax transmition. Now is switched for printing only when the ERROR transmition is.
    My be is it in Service mode on BIT switches???
    than you
    Bole
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Fax report MP2501
    Originally posted by Bole
    Hi
    than you
    Bole
    User tools/counter -> fax features -> initial settings -> parameter settings.
    Switch: 03, Bit: 0
    Automatic printing of the Communication Result Report
    • 0: Off
    • 1: On
    Switch: 03, Bit: 2
    Automatic printing of the Memory Storage Report
    • 0: Off
    • 1: On
    Switch: 03, Bit: 5
    Automatic printing of the Immediate TX Result Report
    • 0: Off
    • 1: On
    Switch: 03, Bit: 7
    Automatic printing of the Journal
    • 0: Off
    • 1: On
    Switch: 04, Bit: 1
    Automatic printing of the Communication Failure Report
    • 0: Off
    • 1: On
    This and other other user parameter settings SHOULD be in the user manual in the fax features section. I usually look in the MP201 manual if I can't find it in the native machines manual since I believe fax setting are the same for nearly every Ricoh MFP made in the last decade.
    • Bole
      • Dec 2012
      • 34
      Thank you. Corect
