RICOH MP C5502 problem for speed copy
  • tecnomarco
    • Jul 2011
    • 214
    have a ricoh mp c5502 to make a photocopy a lot of time spins .. turn and after 20-30 seconds do a photocopy ... what can it be?
    • 37556
    Re: RICOH MP C5502 problem for speed copy
    You do not need to post the same problem in more than one forum.
    • Rich
      • Mar 2011
      • 30
      Had a similar problem with an MPC4502 a couple of years ago. RD144057.doc
      Another Tech had changed some SP modes to stop cold offsetting which increased the warm up time of the fuser from standby.
      I've attached the Ricoh bulletin so you can check the fuser settings. Putting them back to default solved the problem.
      RD144057.doc
