MP 3350 MARGIN
  • stefatric
    • Jan 2019
    • 9
    MP 3350 MARGIN
    [ATTACH]41566[/ATTACH]
    not considering the line on the drum
    • 37460
    Re: MP 3350 MARGIN
    Looks to me like paper is fed SEF and the side fences in the paper drawer are out of position. Possibly a broken tooth on one of them.
    • davel
      • Oct 2011
      • 1103
      Re: MP 3350 MARGIN
      Judging by the line it was LEF, if that is the counter page printed look at the registration.
        • 37460
        Re: MP 3350 MARGIN
        I see the drum line you're talking about. That far off on side registration is almost always the rear side fence being too far to the rear. That much is not adjustable through registration.
          Re: MP 3350 MARGIN
          Originally posted by stefatric
          [ATTACH]41566[/ATTACH] not considering the line on the drum
          OK if i read it right.. LEF feed... 820k.. how many on ADF?
          from the looks of it a copy or print?
          PRINT you do have Drum issues (lines/dots)..
          IF copy.. is slit glass clean(line)? spots still on drum
          you still have feed/timing issues.. but lets narrow down things a bit...
          either you mentioned all the page counts on drum/dev/fuser etc -or- I just missed it.. would be nice to know those stats
          have PM cycles been done on time and properly?
          so many questions ... so little time!
          • stefatric
            • Jan 2019
            • 9
            Re: MP 3350 MARGIN
            • Mark Bbb
              • Jun 2012
              • 1662
              Re: MP 3350 MARGIN
              This machine is not standing on its original kabin.
              And if it is, then it is positioned wrong, because the tray is not alligned with the cabin.
              I think you bought this machine without knowing this problem occured, whright?
              So, we don't know the history of this machine...
              It could be it undergo a shock or so (during transport)?
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                Re: MP 3350 MARGIN
                I suspect it is the registration unit.
                Aye! Cut the crap
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Re: MP 3350 MARGIN
                  it could also be that there is a failure in detecting the paper format
                  • stefatric
                    • Jan 2019
                    • 9
                    Re: MP 3350 MARGIN
                    I have found this spring detached in the direction of the indicator as seen in photo....Does anybody know where it must be placed?
                    I have noticed that the friction of tray 1 is broken. I have replaced it but the situation remains still the same. Is there anything else I have to check?
                    • stefatric
                      • Jan 2019
                      • 9
                      Re: MP 3350 MARGIN
                      part 22 is broken and 21
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Re: MP 3350 MARGIN
                        The strange thing is that the image on the paper is not skewed (posted phtograph).
                        I know this problem of broken bushins only too well, but it always came also with skewing...
                        So, were both springs and both bushings broke?
                        • stefatric
                          • Jan 2019
                          • 9
                          Re: MP 3350 MARGIN
                          no..sometimes the image on the paper is skewed...
                          only on right spring and bushing is broken
