Question regarding 2-3 hole punch unit on a sr3110 booklet finisher
  • fshead
    • 2376
    greetings
    I am running a spc830dn that i connected to a sr3110 booklet finisher that has the 2-3 hole punch unit.
    When i go to accessories i see i can hit 2-3hole punch,2and4 holes EU and 4 hole type NE.
    Can these be configured to any of the 3?
    I do see more that 3 hole cutters on the unit
    thanks
    • 37483
    Re: Question regarding 2-3 hole punch unit on a sr3110 booklet finisher
    You probably see 5 individual cutters. 2 are for 2-hole punching and the other 3 are for 3-hole. The 2-4 hole punch is only available in EU, Europe. It is a physically different punch head. You might be able to select it but will only get 2 and 3 hole punching.
    • fshead
      • 2376
      thanks
      i saw the 5 cutters.
      I am having issues trying to figure out how to configure printing using the booklet fold option.
      I have seen it on mpc3003/mpc4503 and the option shows up on the screen when using copy mode but I cant
      figure how to do it in pcl6 nor ps3 drivers installed.
      It shows the right model sr3110 on the screen and when i check accessories...
        • 37483
        Originally posted by fshead
        thanks
        On the accessories make sure the SR3110 finisher is checked and applied.
        On the print Properties go to the Detailed Setting tab select finishing, staple: 2 at center.
        • fshead
          • 2376
          thanks
          all is on but what i dont see is the fold option that i see when i look at a mpc3003 that has a booklet finisher option..
          does the sr3110 Not allow the fold option that sits below the staple and punch in finishing detailed settings?
          • fshead
            • 2376
            I installed both spc831dn and mpc4502 on my PC and added the sr3110 and it looks like you can not ask prints to just fold like
            you can on the mpc3503 and mpc4503 sorters.
            I dont install many sorters on color units i sell.
            Another lesson learned
              • 37483
              thanks
              If you send a single sheet job to a booklet finisher and select staple 2 center, it will just fold.
              • fshead
                • 2376
                Thanks.
                At first i thought maybe it was not in the design.
                I will run it tommrw
                • fshead
                  • 2376
                  you were dead on.
                  it folds on single copy staple 2 center.
                  I guess multiple sets are not an option.
                  that sorter weighs a ton,i thought i could just lift it into my van by hand.
                    • 37483
                    you were dead on.
                    If there are 2 or more sheets, it assumes that you want them stapled.
                    You can lay it on the back side and slide it in using a sheet of card board. Stand it up and tie it in to transport.
