RICOH MP C3503 how to reset code error firmware E 36
  • tecnomarco
    • Jul 2011
    • 214
    Hi everyone, I have a problem with the firmware updates of a RICOH MP C3503 when I try to install a new firmware give me this error code 36 ... is there a way to reset it? ..... I also tried other SD but this error always appears this message
    An error occurred during the last firmware update.
    Error code
    36
    An error has occurred. Switch the device off and on again.
    When the device is restarted, specify a correct firmware and repeat the update.
    Re: RICOH MP C3503 how to reset code error firmware E 36
    An error occurred during the last firmware update. Error code:36
    are you a Ricoh tech?
    how did you configure the USB drive w/ firmware?
    • tecnomarco
      • Jul 2011
      • 214
      i solved this problem thank you!
        Thanks for letting us know... now for the rest of the class.. WHAT was the fix?
        • fshead
          • 2376
          i always remember who is too busy to drop a quick,this is what i did to resolve the issue...
            • 37533
            To my knowledge, firmware E error codes have to do with trying to do updates from the SP main menu. Could be that the machine is not configured for @Remote.
            • tecnomarco
              • Jul 2011
              • 214
              I simply reformatted the SD card with the program "SD CARD FORMATTER" and I reinserted the SD card ... it did not give me more the E36 code and I made the updates even if before starting the updates it is necessary to insist for 3- 4 minutes before the updates start
