It might be also an NVRAM(LOCATED IN THE CONTROLLER UNIT),PROBLEM,you just have to replace it and see if you have the same problem,
Dont forget to make an SMC LIST OUT PRINT AS YOU ARE GOING TO MISS THE ADJUSTMENTS OF THE OLD nvram! 5-990 I THINK IS THE PROGRAMM THAT YOU MUST PERFORM!
GOOD LUCK!
