MP-402spf
  • mita
    • Sep 2010
    • 87
    MP-402spf
    I have a MP-402spf that has a waste toner full light on and I can't find anywhere to reset this. The pcdu life counter is reset in the PM sp and this is an AIO type unit so it should reset on install any help would be appreciated!
    Brian
  • dave w
    • Jun 2015
    • 230
    Re: MP-402spf
    The waste bottle is part of the toner cart.
    • mita
      • Sep 2010
      • 87
      Re: MP-402spf
      yes, as I said it's an AIO (all in one) however it has a waste toner full flag that I can not find anywhere in the manual. There are references to alarm on/off and a output value that you can view ie 7-931-017. I just am at a loss here
      as to why it does not auto reset with a new unit.
      Thanks for the reply!
      • dave w
        • Jun 2015
        • 230
        Re: MP-402spf
        A poor electrical connection between the Waste Toner Sensor Terminals of the Transfer Unit and the mainframe has caused the unit to falsely display a “Waste Toner Almost Full” message
        IMPORTANT:
        • Clean the entire surface of all five (5) Waste Toner Sensor Terminals.
        • Make sure that no cloth fibers stick to the Waste Toner Sensor Terminals. (Fibers may become attached to the terminals during the cleaning process.)
        Found on My-Ricoh
        Hope this helps
        Oops this may be the wrong model but let it up just in case
        • mita
          • Sep 2010
          • 87
          Re: MP-402spf
          Yeah, I have seen that one but unfortunately it's for a copier with a right side door and transfer belt in it. This one is more like a printer cartridge unit machine.
          • The_man
            • Jan 2016
            • 40
            Re: MP-402spf
            yip think waste is emptied into toner cartridge, so change toner cart should solve problem
            • davel
              • Oct 2011
              • 1109
              Re: MP-402spf
              The toner cartridge is separate from the PCU, change the toner.
              • sturmtrooper
                Copier Combobulator
                • May 2016
                • 587
                Re: MP-402spf
                They are not AIOs the toner and drum are separate. Most likely the waste toner is actually full, or the chip on the toner cart thinks it is. Try replacing the toner cart first. If that doesn't work the four prong connector that touches the chip on the toner cart can get damaged, even if it looks perfectly fine it might be dead.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Re: MP-402spf
                  +1...change the toner
                  • mita
                    • Sep 2010
                    • 87
                    Re: MP-402spf
                    Thanks for the input!
