SP5200S SC195
  • The_man
    • Jan 2016
    • 40
    [Error Code] SP5200S SC195
    Hello, Sp5200s with SC195, serial data missing etc, Tried inputting serial number via SP and also SSP (they were already there) fitted new EEproms to BICU SC669-63 now, tried new NVRAM, (tried uploading info to SD card first on old NV no joy) Can anyone tell me what the prefix means on the SC669-63. manual does not cover -63, this might help me diagnose the fault more. Thankyou
  • fshead
    • 2378
    Re: SP5200S SC195
    i dont see no sub codes here.
    you sure the eprom went in correct.
    I ve never had any issues wth these except lower fuser rollers wrinkling and one wth please wait and not the HDD.
    • sandmanmac
      • 3990
      Re: SP5200S SC195
      Telling us what led to the issue might help us more too...
      Did it just happen just out of the blue? Did you do something to try and fix another issue? Or did you find the machine in this condition?
      Sounds to me like the BICU may have been swapped without the original NVRam
      • The_man
        • Jan 2016
        • 40
        Re: SP5200S SC195
        Found device like this SC195 swapped eprom for new and board, this got rid of 195 but now comes up wrong model, reset as per fitting new eprom, no good, got into factory mode(143) and reinput serial number no good, going to another device tomorrow will check settings on this one as cannot find which model, pnp maintenance id values to put in, obvs destination in this case EU. Thanks.
        • The_man
          • Jan 2016
          • 40
          Re: SP5200S SC195
          Fixed, with another new NVram and ctrl board...!!!! Settings went in straight away now ok.......mystery..ps tried old board back in machine SC195....
          • 1nt3rn3t?
            • Oct 2022
            • 2
            Re: SP5200S SC195
            hello, my ricoh sp5200s have the same error SC195, i think the nvram data was erased,
            Could you please send the data from your nvram, so I can copy it to mine?
            sorry for my english, i am argentinian and a bit stupid
              • 37643
              Re: SP5200S SC195
              WON'T WORK. Serial number mismatch, engine data mismatch etc.
              • 1nt3rn3t?
                • Oct 2022
                • 2
                Re: SP5200S SC195
                What if I modified the file from the computer, changing the serial numbers of the file?
                  • 37643
                  Re: SP5200S SC195
                  You have to buy a new NVram from Ricoh parts. It will require one SP entry at power up.
