Rcoh MP7503 and MPC 5504ex with sadf
  • TechnicianWilson
    • Mar 2017
    • 4
    Re: Rcoh MP7503 and MPC 5504ex with sadf
    Originally posted by JonManchester
    If your machine has an SP6901-1 Set it to 1 from zero. It allows higher stackability which slows down the adf a little to eliminate the Jam 63 separation jams. Also we have been taking the old reverse roller hub (Black) and putting the AF03-2080 Rubber on that Black hub with great results, no need for spacers because the black hub is wider than the blue hub the 2080 tire was on. Also ive been trimming the highest mylar that sits on the reverse roller down a little and that has worked great too. I've even removed them without any issue. I think that mylar sits too high allowing the paper to go over the reverse roller causing the jam 063. There is custom firmware for the MP6503 that slows down the adf and it works also, but the SP6901-1 needs to be 0 not 1. With these steps all machines we have had the problems with have stopped. Have a good day!!
    We have a MP C3004 with j063 fault (separation sensor) after about 50 pages, swapped lots of parts, firmware, all to no avail. Tried SP6901 to 1, perfect. Tested over 500 pages, no jams.
    Thanks so much. JonManchester
    • davel
      • Oct 2011
      • 1104
      MPC4503 has no SP6901
        • 37488
        Ricoh might have moved it to Factory ASP mode. They have done that in the past with SP modes that techs like to use for certain problems.
        • davel
          • Oct 2011
          • 1104
          #19
          Tried that.
          • JonManchester
            Technician / Shop Manager
            • Aug 2013
            • 103
            #20
            The MPC 03 series have SD/Card Firmware for Accessories firmware for the DF3080SPDF. No need for SP6901. The firmware addresses the timing issue. With the tips stated above and firmware your issue should be resolved.
            Live for something or die for nothing.
            • davel
              • Oct 2011
              • 1104
              #21
              Was not on the OZ website yet when I checked.
              • limo
                • Jun 2008
                • 103
                #22
                Bulletin is removed from the website.was present for only two days.I dont know the reason may be pricing reasons.FIRMWARE IS PRESENT FOR ALL THESINGLE PASS FEEDER
                • davel
                  • Oct 2011
                  • 1104
                  #23
                  They appeared 3 days ago, wait now for part to be available.
