Ricoh mpc6003 sr3140 finisher shift tray full remove paper
  • homer
    • Nov 2009
    • 18
    I have a mpc6003 with a sr3140 finisher. it only happens with ledger size paper. the only way to clear it is by turning machine off and on ,with main power switch. I have updated the firmware. Any help would be appreciated.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Ricoh mpc6003 sr3140 finisher shift tray full remove paper
    Does the shift tray travel to it's lowest point and just sit there when this happens?
    • homer
      • Nov 2009
      • 18
      no it just stays in place. doesn't matter how many.
      • TonerMunkeh
        Professional Moron
        • 3865
        Homer did you get anywhere with this? I've got an SR3150 attached to an MPC5503 doing the same thing sorting or stapling on A3, fine on A4.
        Hit it.
        • zed255
          How'd ya manage that?
          • 1024
          I have seen this where the sensor flag was not quite in the sensor (talking shift tray lift here). Adding a little electrical tape to the bottom of the flag stopped false tray full / won't reset issues. No pic handy, sorry.
          • TonerMunkeh
            Professional Moron
            • 3865
            Well. It turned out to be the lift brackets on the finisher shift tray were bent, the machine must have been trying to lift the tray back up when it hit something, bending the tray down.
            Hit it.
            • tufbnme
              • 493
              I keep a set of those brackets in stock because they bend so easy and straightening them hardly ever works.
              • blazebusiness
                SanDiegoCopierRepair.com
                • 1257
                I've had this happen also. Ricoh's finishers are now so flimsy, we get a lot of calls due to bent stuff.
                • guitar9199
                  • Sep 2016
                  • 1100
                  I've been lucky so far with bent brackets being straightened.
                  By the way...LOVE your signature line!! I've got a better one.....
                  "If it jams...FORCE it!
                  ...If it breaks...it needed replacing anyway!"
                  • bijuv8464
                    • Jan 2020
                    • 1
                    did you get solution. if you get please share me .me also facing problem
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      There are solutions IN THE PRECEDING POSTS...read them BEFORE asking dumb questions maybe?
                        • 37533
                        This thread was started nearly a year ago. We do not like grave diggers. If you want help, start a new thread and be very specific as to what the problem is and exactly what you have tried on your own.
                        • Dartman
                          • Nov 2020
                          • 2
                          Try formatting the IMH part of the HDD
