Ricoh 2022 fax & hard drive question
  • copyaction
    • Oct 2007
    • 991
    Customer has 2022sp with print scan fax and hard drive.
    Can I remove the scan and hard drive and just leave it with print and fax options without having the "fax address book" error message?
    Had to replace hard drive twice for "please wait" issues, and customer doesn't use scan and would be happy with just print and fax.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    nope, you will not be able to do duplex coping if you take out the hard drive. the adress book error can be removed with an SP code.
    • skinnypuppy
      CopierJanitor/Geargluer
      • May 2008
      • 92
      Nope you can't, go and buy a used laptop hard drive 40gig format fat32 I get them for about 30bucks and away you go
      • copyaction
        • Oct 2007
        • 991
        I know but, as I said I already replaced it twice so I think something else is taking it out.
        • Captain Scott
          • Dec 2008
          • 166
          How often does the h/d fail?
          • nmfaxman
            • 1702
            I have run into this.
            It turned out the customer was turning off the main power switch every night.
            I told them to let the machine turn itself off and the problem went away.
            • copyaction
              • Oct 2007
              • 991
              since march 2008 the hdd has failed twice.
              they don't ever turn the main power switch off because they get faxes overnight.
              since this was a lease return when I sold it to them in march, I assumed that the previous owner may have been powering it down improperly causing the first failure, but since the new owner never turns it off must be something else.
              • E Winter
                I'm not entirely shure where this machine generation does store the adress book but these fax-related data loss/error can also be forced by a bad connection of the MBU (memory board unit - is hooked on the fax board) or if it's battery switch is not set up to "ON".
                • copyaction
                  • Oct 2007
                  • 991
                  I have pulled the machine into the shop and removed hard drive.
                  I can definitely say that the duplex and sort function do work without a hard drive installed.
                  anyone know which sp will clear the address book error message?
                  • E Winter
                    turning off and on the machine does reset the sc code but that won't help until you fixed the problem what is forcing this error message.
                    Like I mentioned before you should take a close look at the MBU. And mayby you should do a factory reset of the fax module: entering service mode -> fax SP - > don't have the rest in mind but that's self explaing if you see the options inside the fax SP.
                    • copyaction
                      • Oct 2007
                      • 991
                      thanks for the ideas
                      yes I did check the memory board on the fax module, I reseated it and the battery switch was on.
                      tried reset in sp mode for fax but still has code, so maybe the hard drive is needed for fax option?
                      • E Winter
                        AFAIK the HDD is only neccessary for the print/scan function. Are there any SC codes logged in the SMC data?
                        • copyaction
                          • Oct 2007
                          • 991
                          yes I am not in front of it right now but it was something in the 800's like sc 807
                          • marctripp
                            I can't remember if this machine uses it, but many of these machine can use an "Address book" SD card to store the fax addresses if they do not have the print/scan function. However without the hard drive you may lose some other functionality.
                            Marc
                            • E Winter
                              This machine is from the pre-sd card era
                              Well I've found different adressbook related SC codes:
                              SC 870:
                              - adress book error due to bad software or hdd
                              try fw update
                              replace HDD
                              SC 871:
                              - adress book wich is written inside the FCU is bad
                              check/replace MBU
