AF-2090
  • Polo-022
    • Sep 2007
    • 486
    AF-2090
    This copier has 6 million copies. When i select two sided copies with two staples, it throws out the first set and it pops out Jam code 020 every time. Only at this mode. (For examble duplex mode works fine-no jams at all).
    I have cleaned paper feed/transport rolls at duplex tray/inverter,i lubricated stapler, with no effect. In logging data there are also fuser exit sensor jams (015). Does anyone had the same experience? It looks like timing problem but i can't explain it. Thanks for any input.
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    I don't know jack about this copier, but my troubleshooting guide suggest the following for your jam code:
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      If you haven't already, replace the driven and non driven inverter (duplex) rollers and the solenoid. Also check the duplexer clutch, the alignment guides for wear and the turnover guides for wear.
      • lary leon14
        • Oct 2008
        • 44
        I think it's the motor that drives the belt which take out of the finisher the stapling pack of parer.Try to change it with another one!
        Who let the donkey out?
        • Captain Scott
          • Dec 2008
          • 166
          015 Jams
          When last have you replaced the fuser exit sensor ? Look for paper nicks on actuator. That sensor does cause jams if damaged. I have replaced heaps in the past.
          • Lagonda
            • Aug 2008
            • 1649
            Had very simular problems and it turned out to be a forwarding clutch in the duplex unit slipping.
            While you are working on such a high milage machine have a good look at the stapler joggers to see of they have deep paper cuts in them. Gave me a lot of grief until I spotted why the job was skewing and miss-stapleing.
            • techspec
              • Dec 2008
              • 128
              Inside the finisher on the staple tray there is a timing belt which has a 2 paper exit pawls on it, one will be missing.
              Part numbers are: Paper exit pawl B302-4771.
              Washer A353-2763
              Nut 0710-0020W
              Pan Head screw 0242-0035B
              As a matter of course when I attended one of these machines I make sure that these exit pawls are secure.
              Hope this helps
              • Polo-022
                • Sep 2007
                • 486
                It is an SR-840 Finisher with only one paper exit pawl. Others, SR-860 for ex., have two. I checked it and thanks for your input.
                I suspected wear on duplex/finisher metal joggers,turn guides/buffles at duplex tray, so i am waiting for the parts. I will replace duplex clutch,duplex feed-in sensor and fuser exit sensor. Many thanks to all for your interesting..
                • pro.b.unal
                  • Dec 2008
                  • 42
                  Bu arılzarın aynısını yakın zamanda bende yaşadım. Baktığım makine 18 milyonda idi. J 15 arızası için fusing exit senlerini değiştirin çünkü kagıt geçtikçe sensor üzerindeki gaganın yüzeyini aşındırıyor. J 20 dublex inverter sensor arızası, dublex ünit içerisindeki kağıtıdın dünüş yaptığı guidelerı aşındığı için bu guideları değiştirin. eger malzemeler elinizde yoksa selenoidlerin ayarını 3 mm daha yüksek ayarlayarak sorunu çözebilirsin.
                  sorry, I'm learning english
                  j 15 paper jam= replace AW20 0008 Paper Feed Sensor - Fusing Exit
                  j 20 paper jam= replace B070 4661 Gate Pawl duplex,B070 4641 Guide Plate duplex:Lower and
                  AW02 0064 Duplex Entrance Sensor, or dublex selonoid positions adjustment
                  • iMind
                    Vacuum Cleaning Expert
                    • Mar 2008
                    • 1116
                    • pro.b.unal
                      • Dec 2008
                      • 42
                      sorry, I'm learning english.
                      J 15 paper jam= replace AW20 0008 fusing exit sensor
                      J 20 paper jam = replace B070 4661 Gate Pawluplex, B070 4641 Guide Plateuplex:Lower,
                      AW02 0064 Duplex Entrance Sensor, or selenoid positions adjustment
                      • pro.b.unal
                        • Dec 2008
                        • 42
                        j 20 paper jam= replace B070 4661 Gate Pawluplex,B070 4641 Guide Plateuplex:Lower and
                        • pro.b.unal
                          • Dec 2008
                          • 42
                          [quote=pro.b.unal;53028]sorry, I'm learning english
                          • Polo-022
                            • Sep 2007
                            • 486
                            Take it easy boy.... I really understand you!!
                            Well i have these parts and tomorrow i will confirm....Many thanks anyway!
                            • dakke
                              • 10
                              Re: AF-2090
                              What was the solution ? i have the same problem ! Thx !
