We have a KM 8050 that will print solids great but when a screen background is behind it the screen has horizontal lines running through it. If we move the image on the sheet the lines stay in the same place.Not on the image but on the sheet. Put in another transfer unit (used) just to see if this was the problem, same thing lines stay the same. Looking at the fixing rollers, no line are obvious.
Also if we run single colors the lines are on each color the same.It is very hard to make them out on a solid.
Any ideas. Is there an adjustment to the fiery that needs to be made or is it coming from the developers?
