Ricoh MP 4500
  • Pulsara
    Technical Manager
    • Aug 2015
    • 27
    Ricoh MP 4500
    Hi all, I have Ricoh MP 4500 copier with this kind of fault. paper is feeding but it will jam at fusing exit section. found that photo sensor on right cover malfunctioned. when I replaced new sensor, again after feeding new copy it also found defective. changed all wiring harnesses, IOB board which all sensors are connected but problem still there. repeated process with three sensors & all are defective now. when I use sensor off mode by DIP switch 2 on IOB, copies are feeding well. Can some one has an advice for this is a great help. Thanks in advance!
  • TonerMunkeh
    Professional Moron
    • 3869
    Re: Ricoh MP 4500
    The cushioning pads on the exit unit solenoids are a classic cause of fusing exit jams.
    Hit it.
      • 36607
      Re: Ricoh MP 4500
      A jam code would be helpful.
