any idea how to solve mp6500 sc672
  • hsh6049
    • Jul 2012
    • 64
    hey guys
    anyone ever solved sc672 issue...been try reconnect controlboad cable reinsert memory stick unplug hardisk
    machine on..please wait and then come with error code sc672
    please help
    thanks a lot
  • Brianneoe
    • May 2015
    • 322
    Re: any idea how to solve mp6500 sc672
    SC 672 replace RAM on controller (G3325721) 4/4/2008 Helpful
    SC 672 Controller startup error - reseat System SD card 6/25/2008 Helpful
    SC 672 Controller startup error - CN 347 IPU pcb pins bent or connector loose 6/25/2008 Helpful
    SC 672 Controller start up error - Replace standard memory 256 Part number G3325271 7/24/2008 Helpful
    SC 672 Controller startup error - Check damage connection between bcu cn251 and IOB cn227 7/24/2008 Helpful
    SC 672 Controller startup error - Insure that system sd card is installed in slot C1 7/24/2008 Helpful
    SC 672 Controller startup error - Operation panel PCB defective 7/24/2008 Helpful
    SC 672 Controller startup error - Poor connection on motherboard cn300 replace PCB 7/24/2008 Helpful
    SC 672 Controller startup error - Replace BCU PCB 7/24/2008 Helpful
    SC 672 Controller startup error - Replace CNB board 7/24/2008 Helpful
    SC 672 Controller startup error - replace controller PCB 7/24/2008 Helpful
    SC 672 Controller startup error - replace controller PSU 7/24/2008 Helpful
    SC 672 Controller startup error - Replace fuse on controller PSU 7/24/2008 Helpful
    SC 672 Controller startup error - Replace IPU board 7/24/2008 Helpful
    SC 672 Controller startup error - Replace Network card 7/24/2008 Helpful
    SC 672 Controller startup error - Replace system sd card 7/24/2008 Helpful
    SC 672 Controller startup error - Replace transfer unit and IO board as a set 7/24/2008 Helpful
    SC 672 Controller startup error - reseat IOB connectors and ALL memory Dimms 7/24/2008 Helpful
    SC 672 Controller startup error - Format or replace HDD 2/4/2011 Helpful
    SC 672 Controller startup error - update system fw to 1.13 or higher
    The controller PSU has been a issue for me. Old machine..Good luck
    • mincopier
      • Dec 2015
      • 289
      Control board fixed all of ours
      • hsh6049
        • Jul 2012
        • 64
        i been try whatever i can beside exchange control board... mygoodness
        • MIKON
          • Jul 2015
          • 188
          Try cleaning the contacts on the Dimm .
          • hsh6049
            • Jul 2012
            • 64
            try already, even try to take off memory stick machine on...then please wait after that come with error code
            • hsh6049
              • Jul 2012
              • 64
              hey guys have a look this, suppose the message with english but after first time switch on machine it become other language
              wht would cause the machine change languange itself
              thanks a lot
