SC 670 (MP 201SPF)
  • sharpmind
    • Sep 2009
    • 478
    SC 670 (MP 201SPF)
    After updating the engine firmware by mistake, SC 670 appears in the display. It seems that the firmware loaded is old version. Is there any way to recover the machine from that error except by replacing the controller?
  • guitar9199
    • Sep 2016
    • 1100
    Re: SC 670 (MP 201SPF)
    You could try reloading just the System/Copy firmware in the romdata folder, and see if that recovers it.
    Good luck.
    • sharpmind
      • Sep 2009
      • 478
      Good luck.
      after switching the machine on, performing firmware update is showing in the display. Then it will throw SC 670.
      • guitar9199
        • Sep 2016
        • 1100
        Originally posted by sharpmind
        The problem is that after switching the machine on, performing firmware update is showing in the display. Then it will throw SC 670.
        Is the ONLY thing on the card the System/Copy firmware?
        • sharpmind
          • Sep 2009
          • 478
          no..there are system copy, network support, network doc box, printer firmware in the SD card.
          Is it possible to download the engine firmware from the machine of same model unto SD card?
          • sharpmind
            • Sep 2009
            • 478
            If I change the controller board and use the old nvram, will the controller board be damage again?
            • guitar9199
              • Sep 2016
              • 1100
              Remove everything except for System/Copy, and see if that resurrects your machine.
