SCAN TO FOLDER
  • sharpmind
    • Sep 2009
    • 478
    SCAN TO FOLDER
    How can I make the scan to folder work without disabling the firewall in Symantec antivirus? Applying new rule in inbound rules in advance firewall setting, port 139, 445 exemption does not resolve the issue. It happens only when computer name is used instead of using IP address in the shared path. Any ideas?
  • totoro
    • 568
    Re: SCAN TO FOLDER
    Check your dns. Anytime I've had issues with computer names it's been a dns issue.
    Totoro
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Re: SCAN TO FOLDER
      Maybe Scan via FTP might be a better option?
      So far I've had no virus scanners or firewalls refuse an exception for FTP scanning.
      • keithxxiii
        Just a tech
        • Nov 2014
        • 468
        Re: SCAN TO FOLDER
        Check on the logs. One of them will point to the service that blocks the scan to folder. And also, since you were scanning thru IP and wants to configure to hostname, your DNS will surely play an important role.
        Aye! Cut the crap
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          Re: SCAN TO FOLDER
          Add a device to Device Trust
          Have you added the machine to the device trust list on the affected computer?
