price policy Ricoh
  • Mark Bbb
    • Jun 2012
    • 1662
    price policy Ricoh
  • zed255
    How'd ya manage that?
    • 1024
    Re: price policy Ricoh
    Don't try to apply logic to some of Ricoh's pricing. There are examples of PDCUs (and other units) being cheaper than a PM kit for said assembly.
    Why are some things barely marked up while others are at 1200%? Dunno. Why does something that *should* be inexpensive come up as 'send your first born' and other items that *should* be expensive aren't.
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      You really want a cherry for that cake? Ricoh USA pricing is half that in USD.
      • Polarbear
        • Feb 2012
        • 1070
        We have found other instances of this as well. Before we found complete fusing units that were cheaper than the belt or hot roller we needed.
        So yes. This does happen.
        It is a good practice to compare prices and not just assume that the lose parts will be cheaper always.
        Press the GREEN button!!
          • 37458
          In most instances when Ricoh charges more for a part for a component than for the component itself that they recommend replacing the component.
          • Gary Bowen
            Bowdog
            • Mar 2008
            • 250
            Rule of thumb in our office has been that when you find that the pricing for a complete unit/assembly is 'fantastically", "unbelievably" better than a sub assembly from Ricoh you keep it to yourself and don't share it - otherwise, Ricoh may catch their mistake and correct it all the sooner. An example was in the early days of the MP C2500 the complete PCDU's were actually priced cheaper than either the PCU or Dev Unit individually. It made no sense to order the PCU or Dev unit - unfortunately, after about 6 months Ricoh caught their mistake and adjusted the price of the PCDU's accordingly.
