deselect 2 side mode ricoh mp 9000
  • antoney suresh das
    • May 2011
    • 103
    [Misc] deselect 2 side mode ricoh mp 9000
    Hi Guys.
    I need your help i cleared the memory after which see that the two sided mode is selected when the machine is idle. I ran thr'o the settings still clueless i have done it before guess i've forgotten can some one help.?
    thanks
    • 37488
    Re: deselect 2 side mode ricoh mp 9000
    With most current most current models you have to do the following:
    1. Select the what you want as DEFAULT on the copy function screen
    2. Press PROGRAM
    3. Press SET AS DEFAULT
    4. Confirm
      • May 2011
      • 103
      thanks slimsob The Boss i knew you'd be the one to answer i will try tomorrow.
