MP C6502 Replace PCU Cleaning Unit
  • rthonpm
    • Aug 2007
    • 2860
    I took over service on a C6502 about a month ago and it's been working until now. There are only 12,000 pages according to the PM counter for the black drum, but it's calling for a new cleaning unit. I've tried manually resetting the counters and resetting the PM counters in service mode, but the message will not go away. Also tried all of the solutions in the Goose Guide for this as well in terms of order of operation. Is there anything else that I'm missing?
    Firmware is up to date as of last week.
    Thanks everyone
  • davel
    • Oct 2011
    • 1108
    Re: MP C6502 Replace PCU Cleaning Unit
    How many prints on the cleaning unit, you will need to replace it.
    • rthonpm
      • Aug 2007
      • 2860
      The message is calling for the black drum's cleaning unit to be replaced. The PM counter only shows 12,922 pages on it, well below the threshold for the PM.
      • davel
        • Oct 2011
        • 1108
        12 k on cleaning unit? If so and you know for sure that it was changed check sensors for lube bar.
          • 37628
          Since you just took over the service recently, I would not put it past the former service provider having cleared the counter without replacing it. My guess is that the lube is worn down to the near-end sensor.
          • ridgemill
            • Sep 2017
            • 192
            For false drum cleaning unit end condition see this bulletin:
            RD135165.pdf
            • rthonpm
              • Aug 2007
              • 2860
              [ATTACH]41958[/ATTACH]
              This may be the issue since the metres line up with the PM counters for both black and colour. It's possible that the sensor is out of alignment. Won't get a chance to get down there for a few days so I'll know for certain then.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                If you clear parts counters on these machines you MUST clear the counter with the RH side doors open or they will NOT reset...especially the Cleaning units.
                • rthonpm
                  • Aug 2007
                  • 2860
                  Got back to the machine and the sensor was stuck. The machine had been moved out of the office for painting and brought back. There's a good bump at the main door in and that may have caused the issue.
                  Thanks to everyone.
                  Sent from my BBE100-5 using Tapatalk
