ricoh spc820dn not fusing.
  • clark
    • Sep 2016
    • 109
    I have a customer running normal copy paper. replaced the fuser and same problem. Image will not stick to paper. Any ideal would be help. no codes.
    Re: ricoh spc820dn not fusing.
    1) were there codes on old fuser?
    2) have you watched fuser temp in SM?
    3) Is it leaving ANY image?
    4) are you SURE it is producing an image B4 the fuser?
    5) did you reset fuser parts?
    6) check fuser for opens?
    7) fuser getting proper voltage?
    • davel
      • Oct 2011
      • 1108
      Troubleshoot the new? fused. Temperature, pressure.
      • tjvincent
        • 280
        Generic toner ?
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          How cold is the environment?
          I'll bet the paper in the trays is freezing cold?
          • davel
            • Oct 2011
            • 1108
            I bet you never have that problem.
              • 37628
              With older B/W models with thick wall hot rollers, I have had machines that would throw warm up errors if room temperature had dropped below 60F for most of the night and had not been brought back up to 60F before power the machine back on.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Oh I dunno about that...I'm in Toowoomba not the Sunny Coast.
                Certainly not as bad as a Sydney winter though ...was born there and spent 40yrs there
