MP 201 FAX set to 9600bps
  • ABS tect
    • Sep 2013
    • 511
    I had a customer call and say that they need their fax data transmission rate set to 9600bps on their MP 201 to send a fax to a specific client.
    I have never messed with this before but found in the SM to go into IP Fax Switch 05 (1-111-006) and change it from 0110 to 0100.
    My question is will this mess up the rest of their faxing to their other clients that they have been faxing to all this time? They are a medical office and i don't want them to be hindered in sending faxes as that is probably half of what they do.
    Thanks.
    Re: MP 201 FAX set to 9600bps
    My question is will this mess up the rest of their faxing to their other clients that they have been faxing to all this time? They are a medical office and i don't want them to be hindered in sending faxes as that is probably half of what they do. Thanks.
    most times setting a fax to 9600 or lower indicates that they have a VOIP system.. choking speeds down allows the system to 'talk' to the other machine reliably.
    • ABS tect
      • Sep 2013
      • 511
      Ok so setting the machine to 9600 won't affect their ability to fax to anyone else just slow their faxing process down?
        Correct.. more n more places are going to VOIP so it can tie in to the digital system.. and they save $$ by dropping analog line
        Caveat us not always as stable as should be
        • rthonpm
          • Aug 2007
          • 2849
          You may want to also turn off ECM in service mode as well. Keeping it on seems to cause more problems than it ever fixes.
          Sent from my BlackBerry using Tapatalk
          • ABS tect
            • Sep 2013
            • 511
            Perfect this is just what i needed....i changed it to 9600bps and all is well. Thank you guys for your help
            • ctuinstra
              • Apr 2011
              • 49
              Changing that changes the speed for ALL faxes, not just the one destination. Think about it, you are changing a system setting not a address book setting.
              I could go on and on about VOIP, but I won't here.
              Turning off ECM does help some in some cases just as putting tape over your Check Engine light helps. It just masks the issue. ECM is Error Correction Mode, so it corrects errors in the transmission. After too many errors, typically 5% or something like that, it deems the line quality to be to poor and hangs up to try again later. Turning off ECM is just allowing all of the errors to go through and not to attempt to correct them, so basically ignore the errors. Yeah, that's a great fix!
              I just love how the telcoms tell you that you need to adjust your baud rate and disable ECM like this is some great technical fix. It's basically saying slow down the machine to 1980 standards and accept all errors because the reliability and quality of our transmissions suxs.
              Opps, I just did a bit. Sorry.
              • guitar9199
                • Sep 2016
                • 1100
                The KEY to all of this is in the name.....
                VOICE Over I.P.!! All of the Analog/digital/digital/analog conversion tends to leave little "gaps" and "glitches" that you can actually HEAR sometimes. When you listen to it, you can still understand what the other person is saying.... but if a FAX machine hears one of those glitches, it literally asks, "What the heck was that??"....and often that's when you get your fax failures on VOIP lines.
                (OK... so maybe the fax board doesn't ACTUALLY ask, "what was that"....but you get the idea!)
