mpc 3004/3504 SPDF3080 slowing the scan to email/folder speed to stop jams
  • Jedi Ben
    Senior Engineer
    • 77
    Hi
    were having problems with customers complaining of jams or pulls to many in the df. even after changing rollers/ belt / sep.
    in service mode you can do a adf freerun mode to test it. the test on an amount of sheets takes 60 seconds. (slow) go out of service mode try scan to folder/email same amount of sheets its way faster 20seconds.
    Were trying to make it slower to save having these calls. sometimes its to do with what the customer is putting through it
    Was wondering if theses an SP adjustment??
    spoke to ricoh they said use sp 6901-002 to 1 then # its made no difference
    i informed customers they can do a4r scanning but then complaints that they have to rotate the document on there pdf
    thanks
    ben
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mpc 3004/3504 SPDF3080 slowing the scan to email/folder speed to stop jams
    What are the counters of the ADF?
    • Jedi Ben
      Senior Engineer
      • 77
      Hi Mark
      only done 32k on the df. its fine on free run and intermittent jams on scan to folder/ scan to email. even the customer asked it would help if it was slower
      • davel
        • Oct 2011
        • 1075
        I have not been able to find free run for SPDF only RADF and I also have jam/double feed issues with a SPDF on MPC 6004, but they scan a lot of carbonless paper sheets, everything replaced still jams even on normal paper.
        • Mark Bbb
          • Jun 2012
          • 1662
          37K, Guides won't be worn jet...
          Sure there must be an RTB on this problem, no?!
          • rhe
            • Feb 2013
            • 51
            Hi
            Try with firmware update -SPDF
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 589
              Originally posted by Jedi Ben
              Hi
              thanks
              ben
              You can adjust where the "top" of the document is in the scanning menu before scanning the document under original feed type. This will prevent them from having to rotate the document in software.
              • Jedi Ben
                Senior Engineer
                • 77
                I feel your pain brother
                • Jedi Ben
                  Senior Engineer
                  • 77
                  Hi Mark,
                  i will have to have a look on my Ricoh mate. ive been flat out this week. its good to kmow a lot of other engineers are having this issue
                  • Jedi Ben
                    Senior Engineer
                    • 77
                    Originally posted by rhe
                    Hi
                    done this mate
                    • semi
                      • Sep 2008
                      • 192
                      There you go since your welsh??
                      • Brianneoe
                        • May 2015
                        • 318
                        This has been a on going problem with these feeders for a good 2 years now. Every time we bring it up all we hear is that Japan is looking into it. So far the only "fix"that have been working for me is to push off the rubber of a AF032080 sep roller (MP6002 and various other models)and push it on to the hub of the ADF roller. Because the roller is a little shorter than the original roller you will want to space it evenly.
                        Push off the rubber, if you try to get under it it will only split. You can just slice off the white sep roller material with a knife.
                        Good luck..
                        • Jedi Ben
                          Senior Engineer
                          • 77
                          THANK YOU
                          this will be very useful for a customer that opens up letters and does not straighten out the creases. Once setting is done i might set it as a default too and tell them from now on scan a4r direction
                          ben
                          • Jedi Ben
                            Senior Engineer
                            • 77
                            Good luck..
                            Thank you Brian will give it a try
                            ben
                            • Jedi Ben
                              Senior Engineer
                              • 77
                              Originally posted by semi
                              There you go since your welsh??[ATTACH=CONFIG]42047[/ATTACH]
                              thank you Semi, will give it a read between calls. You know how it is Six nation Kings
