Ricoh mp 4002
  • Transam1
    • May 2011
    • 48
    Ricoh mp 4002
    I have a machine with code 878-01
    customer is not using a flash drive ricoh manual says replace main
    controller
    anyone have any other solutions?
    Thanks Gary
  • francisco
    • Nov 2009
    • 168
    Re: Ricoh mp 4002
    controller
    Thanks Gary
    format HDD
    • Transam1
      • May 2011
      • 48
      Re: Ricoh mp 4002
      Originally posted by francisco
      format HDD
      do you happin to have the procedure for this
      Thankyou
      Gary
      • francisco
        • Nov 2009
        • 168
        Re: Ricoh mp 4002
        [QUOTE=Transam1;739923]do you happin to have the procedure for this
        Thankyou
        Gary[/QUOTE
        enter Sp mode
        5-832-01
        execute
        or
        take off the HD and format it
        • Transam1
          • May 2011
          • 48
          Re: Ricoh mp 4002
          [QUOTE=francisco;739937]
          Thankyou
          Gary[/QUOTE
          enter Sp mode
          5-832-01
          execute
          or
          thankyou
          • Transam1
            • May 2011
            • 48
            Re: Ricoh mp 4002
            [QUOTE=Transam1;739953]
            thankyou
            procedure no good same result
            noticed in lower feft corner says hdd error does this mean i need to replace the hard drive
            • anpetros
              • May 2011
              • 43
              Re: Ricoh mp 4002
              Disconect the hdd.If the machine works without it (gives a ready condition) (duplex will be missing from the operation panel, as long as some other functions)then replace the hdd.
              • Transam1
                • May 2011
                • 48
                Re: Ricoh mp 4002
                ok thankyou
                • Transam1
                  • May 2011
                  • 48
                  Re: Ricoh mp 4002
                  removed hdd made no diff will not come to ready so do you think
                  it s the board like manual says?
                  • Transam1
                    • May 2011
                    • 48
                    Re: Ricoh mp 4002
                    changed controller board that error is gone but now have 2 new ones
                    627-00 and 819-00
                    any ideas ?
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 197
                      Re: Ricoh mp 4002
                      update firmware
                      copier tech help you
                      • Transam1
                        • May 2011
                        • 48
                        Re: Ricoh mp 4002
                        where might i find the firmware for this i have no support from ricoh
                        Gary
                          • 37641
                          Re: Ricoh mp 4002
                          Gary
                          Your profile shows you are from London. There is no shortage of authorized Ricoh techs in London. Call Ricoh and pay to have one come out.
                          • Transam1
                            • May 2011
                            • 48
                            Re: Ricoh mp 4002
                            thats a big help
                              Re: Ricoh mp 4002
                              thats a big help
                              another user gave the name of the user here to contact.. go back thru posts
