Hi... Please help me with this issue, i have searched thread and not found any similar complaint which is also really odd
Problem: I have worked with the range of smaller machines from 1515 to 201. The right cover opens and closes like a right cover shud
However, to open the right cover of the MP301 is a struggle... Is this just the 15 machines i have encountered or is this an issue with this model.
To ease this problem I have reduced the tension on the spring plate that is screwed on to the discharge plate (located on the right cover) and it has eased this problem a great deal..
My questions..
1] Is this normal to have a tight, hard to open right cover?
2] Have there been any modifications to ease this issue? (I have no direct access to Ricoh)
3] Will there be any other issue i will encounter by me reducing the tension of the spring as mentioned above?
As always, your field observations & experience with same will be extremely welcome.
Thanks Loads
My questions..
Thanks Loads
