Mp301 admin password changed
  • COPIERMAN
    • Jun 2009
    • 559
    i pick up a mp301 yesterday. they have change admin/supervisor information. They have service lock is on. i can get into service mode using the 107 or 143. try web monitor no luck there. Does anybody know how to get around this. I hope didn't just buy a boat anchor. I know can always use for parts.
  • zed255
    How'd ya manage that?
    • 1024
    Re: Mp301 admin password changed
    If admin and supervisor have been changed and you can't access SP modes (SP mode lock on in User Tools or other issue) then a change of NVRAM will be your only recourse.
    • COPIERMAN
      • Jun 2009
      • 559
      Thanks for the reply . will have to go that route.
      • COPIERMAN
        • Jun 2009
        • 559
        i found out it was my java sd card causing problem. If i try going into service mode before everything comes up could get in to it. So i thought about looking and decide to i pulled java sd card and it work.
          • 37489
          That is quite common with Ricoh. Until JAVA has finished loading, you can get into User Tool menu but the only thing you can access is Counter. Same with SP mode, you may be able to get to the SP main menu but nothing else. JAVA can take 5 minutes or more to load.
