Ricoh Aficio MP 301 - smudged line at the top back side of the page.
  • Like1mS
    • Jun 2018
    • 23
    [Misc] Ricoh Aficio MP 301 - smudged line at the top back side of the page.
    Hello, i have ran into a problem.
    Our company has a circle of engineers between different companies,
    and so far no one has the answer for the problem. Also didnt find any one mentioning it on forums here. So i thought would give a shot and post a thread.
    A client MP 301 always prints out a smudged line on back of the page.
    Happens only on a first page of every print job.
    Donor machines are available at hand to experiment with,
    so far drum,fuser, transfer roller was changed and nothing helped.
    Any suggestions? I appreciate any answers. Thanks.
  • COPIERMAN
    • Jun 2009
    • 559
    Re: Ricoh Aficio MP 301 - smudged line at the top back side of the page.
    Have you look at devlp count 7-803-2 this pcu only good for 45,000 copies. what you are seeing is back ground. Could be from drum /charge roller/grounding and bad toner. If you have a pcu try it first. clean out toner hopper and make one copy then if ok run devlp setup. Install fresh toner to make sure it was not causing problem.
    • COPIERMAN
      • Jun 2009
      • 559
      You said drum does that me the whole unit or just drum.
      • copyaction
        • Oct 2007
        • 991
        Replace drum unit and then use genuine Ricoh toner
        • davel
          • Oct 2011
          • 1103
          Replace PCU, D1272110.
          • keithxxiii
            Just a tech
            • Nov 2014
            • 468
            +1
            Aye! Cut the crap
              • 37476
              You have a dirty transfer roller. Replace it and if there is a setting in SP for transfer roller cleaning, turn it ON.
              • omorales
                • Mar 2015
                • 86
                Clean SHAFTRUM:ASS'mp301.jpgY
                • Brianneoe
                  • May 2015
                  • 318
                  Remove the PCU and clean the Quenching Lamps on the upper left side. You can change SP 2996 to a 1 for better transfer roller cleaning. Your sample is showing heavy background on the backside of the print and is indicative of both a need for the drum unit and transfer roller replacement.If the Quenching lamp assy is not cleaned after replacement of the transfer roller and PCU you will have a shorter life on the PCU and roller.
                  Good luck
                  • sandmanmac
                    • 3981
                    I've always snapped the locator pin off the front of the machine, and used the type 1515 PCU.
                    The cost of the unit (for me anyway) is nearly half
                    • Like1mS
                      • Jun 2018
                      • 23
                      Good luck
                      Thanks Brianneoe, cleaning the Quenching Lamps helped, the pages come out clean. I also set SP 2996 to 1. I will try this on a couple more machines and post back.
