Black pages in Ricoh MP 9000/1100/1350
  • liontech
    • Dec 2010
    • 12
    [Electrical] Black pages in Ricoh MP 9000/1100/1350
    Hi guys!
    I need to consult something because I have already tried absolutely everything.I have many ricoh pro 906, mp 9000, mp1350 with the same problem.
    Randomly throws a black page with white lines.
    Do you have any information about this?
    thanks in advance!!
    Re: Black pages in Ricoh MP 9000/1100/1350
    Originally posted by liontech
    Hi guysI need to consult something because I have already tried absolutely everything.I have many ricoh pro 906, mp 9000, mp1350 with the same problem. Randomly throws a black page with white lines.Do you have any information about this?thanks in advance!!
    well how about cluing us into what " I have already tried absolutely everything. " Means?
    Maybe Page Counts?
    Print Error Log and upload?
    PM's done per schedule?
    OEM Toner/Drums?
    PhilB "The Dentist"
    • liontech
      • Dec 2010
      • 12
      Maybe Page Counts?
      OEM Toner/Drums?
      PhilB "The Dentist"
      Phil!I changed everything.. all boards, all units, laser, drum, developer, hdd, firmware.It makes the failure in copies as in prints.
        • 37488
        Check the Drum shaft assembly PN B234 2350. Continuity from the shaft to frame should remain at or below 10 ohms with little or no fluctuation as the shaft is rotated.
        • liontech
          • Dec 2010
          • 12
          thanks bro, I'm going to try it
          • Codex
            • May 2008
            • 704
            Had exact the same problem, changed everything in the machine....last thing i did is to check the drum shaft assy and the drum bearing.......since then (two weeks ago) no service call for random black print......
            Memento Audere Semper
            • djs9164
              • Mar 2018
              • 79
              Hi guys!
              thanks in advance!!
              Does you copy have lead,or trail void areas?
              Sent from my XT1635-01 using Tapatalk
              • Eris lleshi
                • Mar 2018
                • 4
                check the line charge
                • Coptech
                  worker drone
                  • 460
                  Replace the charge corona and see if it is logging any 300 codes in SC history.
                  Also make sure they are not trying to copy money, death certificates or anything with copy protection.
                    • 37488
                    If SC 300 has been occurring, see bulletin for the Pro 1357, attached.
