mp6001 hung up
  • vargue
    • Oct 2011
    • 404
    [Error Code] mp6001 hung up
    my customer call me that sc555 generatend and detect that lamp tungesten wire cut. i get anew lamp 550w 230v and every thing good. after two days customer called me that machine hungs up for 10 seconds and throw sc672. i close switch on/ ff . and it's working again . i replace hdd clean ram .it's not appeared after machine warm up. it's may be not appear in all day.it's throw intermittentley. did any one encounter that befor
  • sandmanmac
    • 3990
    Re: mp6001 hung up
    Just about the most annoying SC code with the most causes on nearly every model.
    Search the site. It's discussed on Many many models.
    Here's one thread that might help: MP7500 SC672
    Good Luck
    SC 672 controller start up error - reseat connectors on controller
    SC 672 controller start up error - remove fax card and reboot
    SC 672 controller start up error - replace Controller PCB.
    SC 672 controller start up error - check jumper on MBU battery is in correction position per FSM
    SC 672 controller start up error - Replace Java Option.
    SC 672 controller start up error - reseat memory dimms or replace
    SC 672 controller start up error - Update System firmware to v1.20J or higher
    SC 672 controller start up error - Reseated op panel connectors
    SC 672 Controller start up error - IPU defective
    • MIKON
      • Jul 2015
      • 193
      Re: mp6001 hung up
      Clean the contacts on the dimm's
      • Dan G
        • Nov 2014
        • 56
        Re: mp6001 hung up
        update all firmware including JAVA - JAVA update is very important fort this SC code believe it or not
        • vargue
          • Oct 2011
          • 404
          Re: mp6001 hung up
          did some one had firmware? 🤔
