Ricoh MPC2800 dirty on first few page
  • brianho80
    • Sep 2009
    • 198
    dear all master,
    i have this dirty copy issued happen every first few pages after machine wake up from sleep mode.
    dirty line will gradually disappear after continuous printing.
    i did clean up ;service PCU unit and transfer belt cleaner unit but problem remains the same.
    hereby i attached 2 copies for reference. ( with dirty line was printer out first copies and subsequent copies, line disappear)
    Anyone please advise what else i need to look into it?
    Re: Ricoh MPC2800 dirty on first few page
    "did clean up"
    well what does that mean? wiped toner up... vac'd the internal?
    "Service PCU & belt"
    what did you do to 'service' them?
    OEM toner or not?
    what do the belt and drums tell you? smudge on them?
    PAGE COUNTS total and service parts.
    • Arcadian
      • Feb 2010
      • 218
      dear all master,
      change the transfer belt, the rubber one. i found after changing the cleaning blade that it didnt help changing the blade, but change the transfer belt help quite a bit, the static is stronger, looks like the static is either to strong and repelling excess toner from it.
      good luck
      • HitMan
        • Aug 2015
        • 170
        After running the acc is the pattern that gets written onto the belt visible at all?
        Sent from my SM-G930F using Tapatalk
        • FrohnB
          • Jul 2017
          • 1919
          Transfer Cleaning Unit. P/N - D0896022
          You said "Serviced" the Cleaning Unit. Does that mean just "emptied and Vacuumed" or did you replace with new (recommended)??
          Omertà
          • brianho80
            • Sep 2009
            • 198
            "did clean up"
            OEM toner or not?
            Hi Phil B,
            i vacuum pcu and belt unit by dismantle it.
            i using original toners.
            For me, drum looks like weak with color start fading.
            • brianho80
              • Sep 2009
              • 198
              Hi guys,
              thanks for the precious advise, will try change the transfer belt and cleaning unit. Will update you all the result.
              cheers,
