setting up printing on MACBOOK PRO problems..
  • fshead
    • 2376
    I am not a big mac guy but can set up the average Mac to print to a ricoh.
    I just dropped a mpc4503 with PS3 and the first 5 MACS saw the printer and ricoh-usa saw the mac os version.
    But then i got to two Macbook pro with different os version and ricoh-use does not see OS and when i download 10.12 and 10.14 PPD installer and run it, I then try to install driver and Mac does not find this printer.
    So I add it using IP address and it refuse to print..
    I did this multiple times.......I dont have a mac in shop so I have to learn wth customers unit..
    Is the macbook like a chromebook?
    is there something i need to do different,airprint etc etc...........
    thanks
    stranded
    • 30303
    Re: setting up printing on MACBOOK PRO problems..
    Make sure you installed the PS card on the Ricoh , check under printer look for PS . To find what Mac OS it running put mouse under the apple and about this mac. Download the correct mac driver for that mac OS. unpacked driver
    Add printer via ip address using LDP not IPP, Change the name of printer or it will use ipaddress as printer name, it should find the printer check add than add the drawers and finisher.
    Check machine if its using account codes?
    You can set up profiles for black copies and color
      • 37533
      Quick question, can you ping both directions?
      • mincopier
        • Dec 2015
        • 289
        Google and Youtube are your greatest pieces of information for these situations. Both have concise instructions and screen shots to show exactly what needs to be done.
        The C4503 is AirPrint capable. Meaning that should just find the printer on it's own. With AirPrint you do not need to download the driver. The drawback is usually codes cannot be used.
        When setting up IP printing I always use the LPD port myself. This is right below where you set the IP address in the driver.
        As mentioned above, make sure the copier can ping the computer. If it cannot ping the computer then it is of course on the wrong network and printing will not work. So unless these are a really old MAC OS, if AirPrint did not find the printer I would suspect they are connected to the wrong network or have bigger problems.
        • fshead
          • 2376
          hi
          I honestly dont know how to enter "cmd" like on a windows based PC for macs.
          All these hybrids laptops and trying to figure out what I need to know..
          • fshead
            • 2376
            If I installed the PS3 option should it not just install normally.
            I will youtube search out more info.
            I dont know how to find the macbooks IP address..IS it the same for all macs?
            The laptops are outside salesman who come into the office"real estate office" and need to print listing to take with them..
            • Brianneoe
              • May 2015
              • 322
              As Slim stated it sounds like the other 2 MACs are not on the same network. I use the HP Jetdirect -Socket Protocol because it uses port 9100 and is the fastest of all the other protocol. There is a "Network Utility".program that is most helpful but Apple hides it on their new OS. Google comes in handy on things like this. If you press the "Command,shift,A" keys at the same time you will launch the Applications window. There is a program called "Terminal" in the "Utilites"folder that will allow you to run a ping command. The example of "ping -c 5 192.168.1.200" will ping your MFP 5 times and give you the results.
              If you get "Request timeout for icmp_seq" means that the ping failed.
              The PPD file for MAC 10.11 through 14 are the same build.
              Upper left Apple Icon,System Preference, Network will get you the IP address Info
              Good luck.
                • 30303
                If the Macs are not on the same network worst case, save file a pdf to flash driver and print from usb port
                good luck.
                Or have there IT correct the wireless issue
                • fshead
                  • 2376
                  good luck.
                  thanks
                  that is what i told them but it went right by them.
                  Now if they are logged in to the sites wireless,lets say ABC COMPANY"
                  then are they automatically in the default IP range"192.168.1. whatever?
                  I have had windows based laptops that were connected to wireless that was in a different
                  router than the printer and could not get them to connect so is that what i might be seeing here?
                  Again I dont have a mac at home so I am learning on site.........
                  I guesss I will have to buy a cheap used macbook to learn from..
                  • fshead
                    • 2376
                    Good luck.
                    GOOD information..thanks
                    • fshead
                      • 2376
                      good luck.
                      I VE been elected IT guy without being asked..All they want to do is to sell houses and have me
                      make what laptop they drag into the office connect and print..
                        • 30303
                        • fshead
                          • 2376
                          thanks
                          I am looking to buy a used macbook just to learn the ins and outs..
                          ANYthing I should look for or stay away from?
                          • StephenB
                            • Aug 2015
                            • 244
                            I've had very similar issues with laptops (anything wireless) setting up to print.
                            I've had offices with multiple wireless access points, if the laptop / mac is connected to a different network, you cannot connect.
                            If they are connected to the "guest" wireless access...they will not be able to print.
                            To test the connection, I hardwired the laptop to the network and turn off wireless. It will auto obtain an IP and gateway...make sure (gateway) it matches the Ricoh.
                            Once on the correct network, set up the Ricoh.
                            • fshead
                              • 2376
                              thanks
                              the only thing i dont think these macbooks will take a cat5 cable.
                              I think they did sign in as guest..Some of them have 20 wireless listings on them..............
