Ricoh Toner Mp c4503 same as MP c4504?
  • Timmytronic
    • Oct 2010
    • 249
    Hiya, maybe a silly question but I have an upgrade to do from a MP c4503 to a MP c4504, and looked at getting some toners for the 4504 as we don't have in at then moment and I have found that some sites say the toner on the 4503 fits the 4504 also. I have heard that the drums for but is this the case for the toners also as we have loads and save me a lot of extra cost at this point.
    Thanks for your time.
    Tim
    • 22808
    Re: Ricoh Toner Mp c4503 same as MP c4504?
    Tim
    from what I googled no
    • Timmytronic
      • Oct 2010
      • 249
      Hiya Phil
      I can't add a pic on my device but will do, Katun offer Ricoh Original and there compatible to fit either.
        • 22808
        Hiya Phil
        Dude look thru other threads where PQ/CQ is the issue....
        the under lying culprit A LOT of times is COMPATIBLE toners...
        frankly once that has been made known in the thread.. I always bail from discussion....
        you are asking for trouble.
        never cared for Katun crap either.
        • Timmytronic
          • Oct 2010
          • 249
          I am not going to use compatible, always an issue, but Katun on there site say the original works on both models, using original.
          • fshead
            • 2356
            Katun has been Not somewhere that I would trust anything...
            If the drums and fusers are interchangeable then then toner should work but tricky ricoh might add a tab or other item on the toner tube end so it might need to be popped off.
            That was the case wth the mpc2050 to mpc2551..
            I have not seen any 04 s yet so i cant say..
            • sandmanmac
              • 3947
              I'm not sure what the point of the question or debate is?
              It's not a question of "compatibility"
              Both machines use Type MP C6003 toner.
              The end
              • fshead
                • 2356
                The end
                AS HE DROPS THE MIC
                • Timmytronic
                  • Oct 2010
                  • 249
                  The end
                  • jonhiker
                    • 661
                    The best place to find the answer is the Product Support Guides. They will show the correct toner with EDP code for the different machines.
                    • sturmtrooper
                      Copier Combobulator
                      • May 2016
                      • 589
                      Tim
                      If you get any newer machines the 4504ex also takes the Type mp c6003 toner. The new IM series color machines use their own toner named the same as the machine.
                      • GhostInTheMachine
                        • Feb 2010
                        • 88
                        The end
                        I can't figure out how the first 5 responses were from people who apparently didn't even read the question. LOL
                          • 22808
                          "Hiya, maybe a silly question but I have an upgrade to do from a MP c4503 to a MP c4504, and looked at getting some toners for the 4504 as we don't have in at then moment and I have found that some sites say the toner on the 4503 fits the 4504 also. I have heard that the drums for but is this the case for the toners also as we have loads and save me a lot of extra cost at this point. Thanks for your time.Tim "
                          I READ the question..
                          the ONLY sites that I found that said you could use one in the other ARE THE 3RD party COMPATIBLE toners...
                          I for 31+ years have been chasing CRAP 3rd party toner problems. EVEN on CTN other 'older' techs have talked about the "SHIT" compatible toners
                          Even ricoh doesn't mention using 6XXX in those machine
                          but your guys can do whateverthefuckyouwant.. I don't give a rats ass..
                          he asked .. I answered
                          • fshead
                            • 2356
                            I read the question too and know mpc6003 toner is the one for the 450 to 6003 but I dont have any mpc4504 or any 04 series so..............The crux of what he wanted to know is will it fit/detect on a 04 series..I didnt need any more info..............go figure
