IM350 new setup
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    IM350 new setup
    So we got one of these new IM350 in. set up the copier . updated firmware.
    Web page is working .. set to DHCP for nic settings
    Ricoh sales guy comes in and tries to set up I.C.E. says it doesnt work.
    I went to see whats up it says no network connection to the internet.
    I pulled out the Web Browser shortcut and placed it on the screen and It doesnt even let me get to Google. no web access.
    Everything looks good in ipv4 settings i have the proper dns (dhcp) proper gateway (dhcp) and valid ip ..(I can access the web page) and subnet is 255.255.255.0
    Is there anyway the web browse function is disabled somehow? i cant find anything on the web page.
    ps wifi is disabled
    I fix copiers ...Well Sorta
    • 37422
    Re: IM350 new setup
    Since WiFi is disabled, did you try connecting your laptop to the network using the same wall jack and cable currently connected to the IM350 to see if you actually have an active connection with internet access? Turn the WiFi on the laptop and use the same network settings as on the IM50.
    • fireater
      • Apr 2006
      • 253
      Re: IM350 new setup
      as i said i can access the web page and can check the settings. and the cable definitely has web access .. its connected to the same switch as my PC is.
      • Athlontini
        • Jun 2012
        • 269
        Re: IM350 new setup
        Does it work if you network it without DHCP? Is it just the web browser function that can't connect, or can nobody print to the MFP at all?
        • fireater
          • Apr 2006
          • 253
          Re: IM350 new setup
          I have now set it to static ip. Yes I can print. It's just the Web browser doesn't work. And that means that I.C.E. doesn't work as it uses the browser.
            • 37422
            Re: IM350 new setup
            I assume that you mean that you can access the internal web page of the IM350. That does not answer the question of whether the port on the switch that the IM350 is connected to is allowed to access the internet. There are controllable switches where IT can specify what can be accessed through each port.
            • Kimi
              • Feb 2018
              • 105
              Re: IM350 new setup
              Can you ping 8.8.8.8 from interface settings?
              • fireater
                • Apr 2006
                • 253
                Re: IM350 new setup
                checked.. unplugged copier. plugged in laptop...network cable works as expected
                Ps we have a regular dumb switch
                • fireater
                  • Apr 2006
                  • 253
                  Re: IM350 new setup
                  yes! that seems to work.. rechecking dns .... dns is set correctly ...
                  dns 1 is set to gateway. It is also our dhcp/dns server / router
                  dns 2 is set to google. 8.8.8.8
                  dns 3 is set to Shaw cable.. our isp dns.
                  makes no sense it should work
                    • 37422
                    Re: IM350 new setup
                    Maybe add 8.8.8 as the third DNS on the IM350.
                    • Kimi
                      • Feb 2018
                      • 105
                      Re: IM350 new setup
                      proxy?
                      • Kimi
                        • Feb 2018
                        • 105
                        Re: IM350 new setup
                        actually, i dont think its proxy if you can already ping 8.8.8.8.
