mp6001 to mp6002 to mp6003 question
  • fshead
    • 2376
    greetings
    I am thinking of upgrading my old 5500 to mp6001 i have in the field that are getting old in the tooth.
    any big advantages or differences between the 3 models?
    thanks in advance..
    ps is there a mp6004?
    • 37484
    Re: mp6001 to mp6002 to mp6003 question
    There is no MP 6003. For the 03, the there is a 65 ppm model not a 60 ppm. The next 60 ppm model was the MP 6054 which has been replaced by the MP 6055.
    • skinnyb
      • Jul 2008
      • 291
      Yes I agree. Went from MP 5500, 6000, 6001, 6002, then the most current jumped to 6503. No 04 iteration in this frame yet.
      Sent from my VS987 using Tapatalk
      • fshead
        • 2376
        hmmmmmmmmmmmm
        I saw a mp7503 offered to me so i assumed mp6003.
        and is the 6503 the same engine as the mp6001?
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          Originally posted by fshead
          hmmmmmmmmmmmm
          While they look similar , some diffferences/improvements as always when a newer generation comes our.
          From the Product Support guide:
          The D223 / D234 / D2235 is the successor for the D131 / D132 / D133
          65 / 75 / 90 (A4/LT) PPM
          Intuitive, but simple UI on newly equipped Cheetah-G2
          Specific Use Apps such as ID card copy
          Smart SDK support
          Customizable operation/error sound
          Only 1.0 sec for ready-to-operate from sleep mode (by Body Sensor)
          Book copy with opening ADF App
          Enhanced GW+ controller
          Enhanced Paper weight support
          Enhanced scan speed
          Auto paper size detect function on bypass tray
          New Features:
          • fshead
            • 2376
            thanks
            SAME TONER,DRUMS AND FUSER LAYOUT???
            • blazebusiness
              • 1250
              thanks
              Same toner and developer/starter.
              Drum ---is the same
                • 37484
                thanks
                Except for the electronics, most of the parts the same.
