MP7502 replace cleaning web
  • GeorgeBest
    • Jul 2009
    • 526
    HI
    Customer with this call, cannot print . . .
    don't have this unit, is there a way to disable the call for a small period?
    Thanks in advance
  • HitMan
    • Aug 2015
    • 170
    Re: MP7502 replace cleaning web
    The web is on a counter there might be some left have you physically checked?
    Sent from my SM-G930F using Tapatalk
    • GeorgeBest
      • Jul 2009
      • 526
      not jet . .
      Originally posted by GeorgeBest
      HI
      Thanks in advance
      • Codex
        • May 2008
        • 704
        Hy... I depends if the cleaning web is really finished (in this case "change cleaning web now" is displayed (no sc 550 in this series) or there is a count error... In this case the messsge is displayed only at the bottom and the customsr can use the machine
        Inviato dal mio SM-G935F utilizzando Tapatalk
        Memento Audere Semper
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          You could pull the web out and re-roll it back onto the supply side and stick it back in. Not elegant but it will make the machine think there is enough web. Just make sure you set the web use counter back to 0 or the machine may refuse to recognize it.
            • 37529
            Since the machine is disabled when the sensor detects that web has run off the supply shaft, it is a good idea to always a good idea to carry at least 1 in your car stock. One thing to check if the web has not run off is the wiring harness. I have had a couple of machines where the wires going to the out switch were rubbing on a screw head and would cause a short to ground. It's a rare occurrence but worth a check.
            • MIKON
              • Jul 2015
              • 188
              a mp6000 mp6001 b1404181 will work enter sp1902 web used to 0 then enter 33# that should allow counter to reach 100%
