Email Reporting Ricoh
  • bush_tech
    • Jul 2018
    • 51
    Hey all
    Just having an issue setting up the 03s and 02s to email counter reports, I've found a thread in which a tech said if the options are missing you can just update the firmware and they will display... I've had no luck with this the options are still missing after update.
    Anyone know of a fix?
    Cheers
    • 37533
    Re: Email Reporting Ricoh
    If you have a machine with the SOP, I believe that you can setup counter emailing by using the Smart Operation Panel Designer tool. The other option is @remote.
    • zed255
      How'd ya manage that?
      • 1024
      The newer machines (02 series and newer colour boxes and some 03 series and newer B&W with up to date firmware) have the option to send meters via email in SP mode. A working SMTP setup must exist in user tools, as used for scan to email or fax forwarding.
      SP5-866-110 set to 1
      SP5-866-121 enter email to send meter to.
        • 37533
        Some also have on demand email reports that are setup through WIM. They are sent when the machine receives a trigger email. Does require the machine being setup to receive email, ei POP before send or POP at fixed intervals.
        • guitar9199
          • Sep 2016
          • 1100
          GW Email.... I've got it set up on one C6003 machine so far, and every month I get the meter reading just fine.
          If the customer does NOT want the machine to have email capabilities, this won't be an option.
          • bush_tech
            • Jul 2018
            • 51
            I should of been more specific, I'm talking about the options in 5-866 being missing even after a firmware update.
            Was wondering if there's something I'm missing
              • 37533
              It might be one of those moved to Factory Mode SP.
              • emiliorsg
                • Jul 2018
                • 141
                I believe that it can only be configured on machines of the series -03 -04 or newer and with the firmware updated. In the mp c2011 I could not do it.
                • COPIERMAN
                  • Jun 2009
                  • 559
                  make sure in user tools that file transfer smtp server email is setup and auto specify administrator is turn on and administrator email is enter.
                  if you have update to latest firmware on copier and you don't see 5-866 then copier doesn't have that feature. i have a mp c4502 it has that feature in service mode. 5-866- set the following
                  001 to 0
                  110 to1
                  114 set to what day to send check 113 will show when next counter report date will send
                  115 hour
                  112 for testing. I had problem where it said it fail so two things i made sure of was setting 113 ahead of the day i was testing also turn off copier and restart copier.
                  • guitar9199
                    • Sep 2016
                    • 1100
                    From my GW Email walkthrough, these are the models that support it. I hope this helps.
                    System/Copy
                    MP C3003SP/C3503SP Ver.1.24 D1475575C (Normal Operation Panel)
                    MP C3003SP/C3503SP Ver.3.16 D1465575C (Smart Operation Panel)
                    MP C4503SP/C5503SP/C6003SP Ver.1.28 D1495569D (Normal Operation Panel)
                    MP C4503SP/C5503SP/C6003S Ver.3.17 D1485553D (Smart Operation Panel)
                    MP C2003SP/C2503SP Ver.1.17 D1775550V (Normal Operation Panel)
                    MP C2003SP/C2503SP Ver.2.16 D1765550V (Smart Operation Panel)
                    MP 2554/3054/3554/4054/5054/6054 Ver.1.16 D2025550T (Normal Operation Panel)
                    MP 2554/3054/3554/4054/5054/6054 Ver.1.16 D2015550S (Smart Operation Panel)
                    MP C3002/C3502 Ver.2.16 D1425610
                    MP C4502/C5502 Ver.2.16 D1445610
                    MP C2004/C2504/C3004/3504/4504/6004 from 1st production
                    MP 501SPF/601SPF from 1st production
                    • keithxxiii
                      Just a tech
                      • Nov 2014
                      • 469
                      How did you managed to upload the destination address? I was trying it with an SD card, created a txt file for the required destination. When I read it from the SP mode, it says failed.
                      Almost created a ticket to ricoh for an explanation.
                      Aye! Cut the crap
                      • guitar9199
                        • Sep 2016
                        • 1100
                        I just keyed it in manually in SP mode.
                        • COPIERMAN
                          • Jun 2009
                          • 559
                          i left out a step to tell it where to email counter report see below.
                          001 to 0
                          110 to1
                          115 hour
                          121-123 enter email where you want the report to go to0.
                          • Brianneoe
                            • May 2015
                            • 322
                            001 to 0
                            110 to1
                            115 hour
                            Your missing a important step to this procedure, After setting 110 to a 1 you need to power down and up the machine and then input the rest of the settings.
                            • lukboruta
                              • Nov 2014
                              • 21
                              I own MP 3353 and some fields are missing, i only have a Report validity and Add Sate Field, firmware are up to date, so does it mean that model cant send reports via 5-866 method? IF doesnt, what these modes are for?
