printing problem, mp c5502
  • tullio
    • Feb 2012
    • 268
    urgent.
    printing problem .
    IMG-20190416-WA0004.jpgprinting problem
  • davel
    • Oct 2011
    • 1099
    Re: printing problem, mp c5502
    PM counts?
    Internal test pages would be helpful
    Generic toner?
    Looks like transfer not sure about grey background
    • COPIERMAN
      • Jun 2009
      • 559
      how many copies on drum /devlp/and what about color copies does it also have problem. try printing single color and see if you have same problem. will help in deciding where problem is. Print smc report will give you how many copies on each component.
        • 37444
        If the problem is with color and B/W, PTR is not making proper contact with the ITB.
        If it is only with black, you either have depleted black developer - replace black development unit or the black transfer roller lift in the ITB is not working - replace the entire ITB. Both are the result of shoddy maintenance.
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Without any data: 1. fuserunit 2. pcdu-bk
          Greetings...
            Originally posted by tullio
            urgent.
            printing problem .
            [ATTACH=CONFIG]42380[/ATTACH]printing problem
            what a plethora of information! and what a fantastic example pic
            how about page counts
            life on parts
            your tech ID#
            • HitMan
              • Aug 2015
              • 170
              Open the right hand door when the page is going through the machine and try and jam the paper at the transfer belt. If the image is fine there then the fuser will be the issue. I'm guessing faulty fuser belt or the media you are using is too thick and the settings haven't been changed to suit. One thing to check is user tools maintenance paper type and set all trays to plain paper type 2 might help
              Sent from my SM-G930F using Tapatalk
                • 37444
                life on parts
                your tech ID#
                Phil, with that many red cards do you really expect him to have a Tech ID#?
                • MIGUELMARCHENA
                  • Feb 2018
                  • 191
                  if it is transfer is because it is not well accommodated the transfer rudder or the complete box discomfort but but, I would say, is fusion problem Maybe the sleeve is already damaged, it did not put adequate temperature etc
                  • HitMan
                    • Aug 2015
                    • 170
                    Yes
                      wellll.... I guess you busted me on that one Slim!
                        can't be any rudder ... nor a keel
                        "or the complete box discomfort "
                        WTF?
                        I would say, is fusion problem"
                        no I think it's more of a Fission problem.
                          • 37444
                          WTF?
                          Does it seem to you that this is starting to become a random though thread?
                            Aren't most like this? I can think of 10+ since weekago
                            • Coptech
                              worker drone
                              • 460
                              WTF?
                              Keel...That is how that Baptists taught me to order a breast at Kentucky Fried Chicken so you didn't have to say "breast" in public. Oh the profanity...
                              Did you know that if you play stairway to Heaven backwards, it is pretty much gibberish? Yep...got that lesson also.
