MP 501
  • francisco
    • Nov 2009
    • 168
    MP 501
    I have a strange problema
    when scan documents with adf(color mode), in some pages a blue line appears
    i tested in 3 machines and all do the same.
  • davel
    • Oct 2011
    • 1103
    Re: MP 501
    Something dirty in the optics, DF glass probably, does it do it when scan off glass.
    • francisco
      • Nov 2009
      • 168
      Re: MP 501
      only whith adf in color pdf multipages
      • davel
        • Oct 2011
        • 1103
        Re: MP 501
        Got to be DF glass
        • francisco
          • Nov 2009
          • 168
          Re: MP 501
          Got to be DF glass
          No.
          lock the direcion of line
          • skinnyb
            • Jul 2008
            • 291
            Re: MP 501
            ADF registration. Change the registration or magnification (like bump magnification to like 102%) and see if it changes. Pretty classic problem for the A4 size devices.
            Sent from my VS987 using Tapatalk
            • francisco
              • Nov 2009
              • 168
              Re: MP 501
              registraction is ok
              is only in scanner and the appears only in some pages.
              • skinnyb
                • Jul 2008
                • 291
                Re: MP 501
                Originally posted by francisco
                registraction is ok
                It's catching the edge of the paper on the way out, when in color mode it picks up the shadow as blue. Change the registration a little each way till the line goes away. Registration will be off a little bit (1-2 mm) but the line will go away. Or just change magnification slightly larger to run the line off the page so to speak. I've never seen it personally on a 501 but have seen it more times than I can count on the SP5210, MPC 400 style scanner.
                • mikadonovan
                  • May 2008
                  • 2931
                  Re: MP 501
                  Not familiar with this box, but on other machines if the scanner glass is installed upside down or backwards, adf reg/feed issues will ensue.
                  NEVER ASSUME ANYTHING
                  • COPIERMAN
                    • Jun 2009
                    • 559
                    Re: MP 501
                    I agree adjust magnification in the service mode in periphs DF magnification adj
                      • 37469
                      Re: MP 501
                      That is usually due to the "scratch proof" coating on one side of the slit glass.
                      • davel
                        • Oct 2011
                        • 1103
                        Re: MP 501
                        Sorry, my bad MP 501 must be SEF.
                        • francisco
                          • Nov 2009
                          • 168
                          Re: MP 501
                          sorry
                          anyone who had this machine in field can do a test?
                          just put some originals in adf and do a scanner in color mode, and see if the cyan line appears.
                          i had the test in 3 diferentes machines and all did the same(cyan line in some,not all)
                          • Gary Bowen
                            Bowdog
                            • Mar 2008
                            • 250
                            Re: MP 501
                            Have you tried what skinnyb suggested and have you checked the slit glass. It seems like you might be over complicating this problem. If you found other machines doing it, then it sounds like it's a built in problem with that product and often you have to find your own fix. Just because an adjustment is "spot on" doesn't mean you won't need to tweak it a bit to find a solution for a strange problem.
                            • sandmanmac
                              • 3981
                              Re: MP 501
                              registraction is ok
                              Leading edge Registration might be fine but if you make a copy of something OTHER THAN A BLANK PAGE, and compare it with the original, you'll see that the image is reduced. As suggested by skinnyb, adjust the ADF magnification in "peripherals"
                              sorry
                              C'MON. Solutions provided, and you've not given any indication that you've tried ANY OF THEM
