We have an mpc 6502 that keeps damaging the leading edge of the paper only when feeding from the internal lct tray 1 and just off center to the rear of the copier by about 1 inch see attached pic
The things we have changed are the complete feed unit and the lct tray which has the added spacer under the area that you screw the tray to the rail. we thought this would have fixed the problem.
All the reg area mylars are in good condition and have been replaced in the last 8 months we are sure the damage is happening before the paper gets into the reg area as sometimes the paper jams befor the reg area due to the damage.
we have tried adj the tray hight to no avail it will damage the paper 4 to 8 times an a run of 10 pages.
has anyone had this.
