SR4130 RICOH
Re: SR4130 RICOH
The Trouble Shooting Guide for this machine recommends updating the Finisher firmware (if you have a version older than 01.040.03 this could be your problem) Also, there was a Technical Service Bulletin for SC720 errors. Either suggestion might be a good starting point.Attached Files -
Re: SR4130 RICOH
Ok, thanks! 😎👌
The Trouble Shooting Guide for this machine recommends updating the Finisher firmware (if you have a version older than 01.040.03 this could be your problem) Also, there was a Technical Service Bulletin for SC720 errors. Either suggestion might be a good starting point.Comment
