MP C5502 White Line issue
  • dbrown33177
    • Feb 2019
    • 15
    A311669D-0B7D-4227-A3E7-18F6D9666853.jpg 338EC388-DF67-4C51-8A93-BB34586D558F.jpg
    I've searched and have tried a few of the options on the forum, but kind of out of ideas now. There is a white line running down every black print. CMY prints fine with no line. First I ran the LD cleaner back and forth just to make sure. Then checked the pcdu. I went ahead and changed the whole development unit and Drum unit. Ran the full dot pattern for black once again and there is still a line in the same exact spot. Tried another laser unit we had sitting around and no change in the line.
    Thanks for the help. It's much appreciated.
  • Gary Bowen
    Bowdog
    • Mar 2008
    • 250
    Re: MP C5502 White Line issue
    Exact same line and in the exact same spot after having swapped Laser Housing and Black PCDU (Drum/Dev Unit)? When I look at your sample copies it looks like lint (or equivalent) that might be blocking a small area along the optical cavity beneath the Black PCDU. The line appears broken in the middle so I doubt that it is anything trapped along the edge of the "Doctor Blade" in the Dev Unit.
    • tufbnme
      • 493
      Need more info. Is the line running from lead to trail or side to side. Check the transfer belt unit.
      • dbrown33177
        • Feb 2019
        • 15
        Yeah the line never changed or moved after the replacement of both parts. That's what has me dumbfounded. Never ran into this before.
        • dbrown33177
          • Feb 2019
          • 15
          It's running from lead edge to trail. I looked at the transfer belt and it had a dimple in it, but it was about a half inch off the line.
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            And colour sky shots don't have the issue?
            I've had something similar where a piece of label was stuck under the plate for one of the handles and was dragging through the image.
            Perhaps swap out the itb assy next?
            • dbrown33177
              • Feb 2019
              • 15
                • 37628
                I tend to agree with Gary Bowen.
                Also you might have a wire or something inside the ITB assembly that has worn a grove in the black transfer roller.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Or a Roach...seen that plenty of times.
                  • davel
                    • Oct 2011
                    • 1108
                    Have a close look at the space between laser and PCU, I have seen a small hair causing strange white line.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      You write:
                      "I went ahead and changed the whole development unit and Drum unit."
                      With new ones or used units?
                      Be honest!
                      • dbrown33177
                        • Feb 2019
                        • 15
                        Originally posted by Mark Bbb
                        You write:
                        Be honest!
                        I used new ones.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          Originally posted by dbrown33177
                          I used new ones.
                          used new ones are not new!
                          • dbrown33177
                            • Feb 2019
                            • 15
                            I meant it as I installed brand new dev units. They weren't used.
                            • guitar9199
                              • Sep 2016
                              • 1100
                              I'm with some of the others on this. It looks like something blocking the window between the laser and the drum unit. Pull the black drum, and inspect the cavity at the bottom. I've even seen something on the UNDERSIDE of the laser glass...and there's no way for the cleaning wand to get to it.
                              Good luck. I have an 03 series with a doctor blade issue on the Cyan I have to deal with later today.
