Can I use a mpc4502 control panel on a mpc3002?
  • fshead
    • 2376
    hi
    I have a mpc3002 that has been sitting wth a shattered control panel.
    I changed the touch screen but the 2nd brd behind it shows cracks too and
    I am trying to get it running to test my batch of fuser units i plan on rebuilding
    to have on the shelf when busy.
    I dont have any mpc4502 in the field but found a cheap working used one.
    Do you see anything that can make it "not" worth a chance to try?
  • FrohnB
    • Jul 2017
    • 1919
    Re: Can I use a mpc4502 control panel on a mpc3002?
    No. C3002 = D1421411 and C4502/5502 = D1441401. Have tried it before and get a code or error message or non start of screen or something, can't remember exactly, but they don't cross over.
    Omertà
    • fshead
      • 2376
      thanks
      do you think the "video brd" crosses over?
      i gotta ck the parts manual........
      • FrohnB
        • Jul 2017
        • 1919
        PCB: OP R and L (under the keys and such) are the same.
        LCDC: TFT: WVGA are the same between C3002 and 4502.
        Touch Panels are different D1291422 for 4502 and D1291421 for 3002.
        PCB: LCDC: FT boards are different. D1441441 C4502 and D1421441 C3002. (I think this is the board you are talking about that is also cracked? Sits right underneath the Touch screen).
        Omertà
        • fshead
          • 2376
          thank you..
          I sometimes get lost looking thru the parts manual...
          • francisco
            • Nov 2009
            • 168
            Originally posted by fshead
            hi
            yes you can
            just put the right panel firmware.
            i had tried and it works
            • fshead
              • 2376
              Originally posted by francisco
              yes you can
              hi
              Are you 100% sure as I have no need for a mpc5502 panel.
              Previous posts say you get a code or nonresponse of screen..
              Did that occur and doing mpc3002 op panel FW brought it back
              and functioning on a mpc3002?
              • francisco
                • Nov 2009
                • 168
                hi
                100% sure
                FW MPC3002
                D1421492F(op panel) D1421499C(lang)
                FW MPC5502
                D1441492F and D1441499C
                • fshead
                  • 2376
                  thanks I APPRECIATE THAT...........
                  • FrohnB
                    • Jul 2017
                    • 1919
                    Let us know if it works! Inquiring minds would like to know.
                    Omertà
                    • fshead
                      • 2376
                      will do
                      have not bought the panel yet still trying to get it cheaper as other machines are more important right now..
                      • davel
                        • Oct 2011
                        • 1099
                        Just fitted MPC4500 LCD to MPC2000 and it worked fine.
                        • fshead
                          • 2376
                          As this mpc3002 i wanted to revive was just to test my fuser rebuilds for that series i waited for a cheap option.
                          I ended up finding a mp400/mp5002 b/w OP PANEL.
                          IT identical and came up w/out even doing any FW updates..Will do the OP panel FW for the mpc3002
                          • fshead
                            • 2376
                            just did the mpc3002 op panel FW and then updated engine,system and all the rest in normal
                            manner and I see no issues using a mp4000/mp5000 OP panel in a mpc3002......
                            This is my test bed unit for some fusers i am rebuilding and need to test if aftermarket sleeves
                            work without fuser codes and fuse toner properly
                            • kleankopy
                              • Feb 2016
                              • 114
                              Good luck with those aftermarket sleeves. We tried but they failed within a few months.
