SOP PANELS QUESTION
  • fshead
    • 2360
    SOP PANELS QUESTION
    HI
    I have seen the mpc401 SOP and the mpc3503 SOP panel but just bought a few mpc4503 SOP used panel.
    With FW are they all interchangeable?
    thanks
  • tufbnme
    • 493
    Re: SOP PANELS QUESTION
    You must always use the SOP firmware on a machine that has a smart panel.
    Be very careful and make sure not to load NOP firmware if a SOP is installed and vice versa.
    • guitar9199
      • Sep 2016
      • 1100
      No...
      The C401 uses the M10 Smart Panel, and the C3503/4503 uses the M3 panel.
      • JayPaul
        • Oct 2012
        • 305
        True, I think just looking at them should show they are different. From memory the '03 models have a touch screen and the physical buttons are on the right hand side and on the 401 the buttons are below the touch screen I think. They are quite different layouts.
        • skinnyb
          • Jul 2008
          • 291
          401 is definitely different.
          Sent from my LM-V405 using Tapatalk
          • fshead
            • 2360
            I havent gotten yet but will fiddle around..
            I have a mpc401 SOP panel wth touch screen cracked and have yet to find a cheap touch screen option.
            • fshead
              • 2360
              hi
              the M3 and M10 SOP panels are the same except for the hinge design.
              I had a bad M10"sc 672 code" and took the metal frame that connects the panel to the mounting hinge.
              I have a 2nd M10 SOP that I might try to duplicate the mounting metal frame or just use in on a mpc3003 to mpc4503 .
              The panel does come up on a NOP panel machine but limited screen
